End of My Rope 95 GT Still bogs when idling above 2,000 rpm - Mustang Evolution
Old 11-26-2017, 08:00 AM   #1
Mr.Five0's Avatar
Exclamation End of My Rope 95 GT Still bogs when idling above 2,000 rpm
Okay fellow 5.0 lovers I have just about reached end of my rope. Car starts right up, dash mounted in line fuel pressure gauge reads 40 PSI at idle.
Still bogs when idling above 2,000 rpm or in drive when I hit the gas, Thus far replaced.
OEM Motorcraft plugs and Wires
Motorcraft 02 Sensors
Performed smoke test vacuum leaks, slight bleed EGR bladder replaced EGR Valve
IAC
Motorcraft Mass Air Meter and sensor complete
TFI Module
Ignition Coil
Cap Rotor
Distributor
Harmonic Balancer
PCV Valve
Motorcraft Canisister Purge Valve
Anyone have any thoughts?, with time and parts cost I have spent about 1/3 the cost of Coyote crate factory motor
Mr.Five0 is offline   Reply With Quote
Old 11-26-2017, 09:20 AM   #2
Revvv's Avatar
Fuel filter
Old 11-26-2017, 09:32 AM   #3
Mr.Five0's Avatar
Fuel Filter
I have OEM one in the box came with tune up kit, did not go that way because car has 40,000 orig miles last changed fuel filter at 28K, I use strictly 100 octane unleaded since new....but yeah cant hurt will lift get under there tomorrow and swap it our, keep you posted, thanks
Originally Posted by Revvv View Post
Fuel filter
Old 11-26-2017, 04:15 PM   #4
Revvv's Avatar
Sometimes it is the simple and stupid stuff that causes the biggest problems.
Hopefully that little part will work a miracle. If not, I will brainstorm with you.
Old 11-26-2017, 07:09 PM   #5
What does the fuel pressure read at around 2000 RPM when the bogging occurs?
Old 11-26-2017, 07:26 PM   #6
Revvv's Avatar
Why didn't I think to ask that?
Old 11-27-2017, 10:23 AM   #7
Mr.Five0's Avatar
Thanks for taking an interest rather than try and describe here's a video I took this morning I appreciate your time and knowledge base
Old 11-27-2017, 10:25 AM   #8
Mr.Five0's Avatar
Video Will not load it basically stays flat right at 40 then when I gun the gas above 3000 RPM psi rises 50-52
Old 11-27-2017, 11:05 AM   #9
Replace the fuel filter as Revvv suggested.
With the engine idling, remove the vacuum line from the fuel pressure regulator located on the fuel rail. The fuel pressure should jump up to around 50 psi immediately once the vacuum line is removed.
Old 11-27-2017, 01:53 PM   #10
smurf stang's Avatar
Have you run your codes?
What is your timing set at?
How does it drive without going WOT?
So you spent $2,000 in what you listed...........?
2016 VW GTI 2.0 Turbo
Old 11-27-2017, 06:34 PM   #11
Mr.Five0's Avatar
No time to detail by item but 13 items at average price of $125 gets me to an easy $1,750. since I did harmonic balancer, O noticed Fords proud plastic 23 year old radiator was ever so slightly starting to leak a shaft base of cap, so I pit in aluminum mishimoto 3 core unit, Since all that was apart a decided to add SVT Tranny cooler. You must be a bean counter by day, thought this was TMI for the purposes of getting knowledge base on root cause, EOD spent more like $2800, keep ya all posted taking off weds to get some gas on me
Old 11-27-2017, 06:36 PM   #12
Revvv's Avatar
Hmmmm nothing like the smell of gas. It's a gear head cologne.
Old 11-27-2017, 06:36 PM   #13
Mr.Five0's Avatar
forgot air pump delete puley
just remembered cats long gone, tube welded off from air pump so I through the paper weight away and replaced with LMR billet air pump delete pulley
Old 11-28-2017, 04:59 PM   #14
Not a bean counter but I do wrench and that is why I asked since none of that should add up to what you said unless you paid someone to do it. Sorry you were offended so easily.
Old 11-29-2017, 01:25 PM   #15
Mr.Five0's Avatar
New Fule Filter In, no change
gents, fuel filter did not make a difference, if anyone is interested in looking at video, It will not up load here.. shoot me an email
bobv12v12@gmail.com thanks
Old 11-29-2017, 07:08 PM   #16
Well, on the bright side, I think that the only other items that you haven't replaced is the Throttle Position Sensor and the fuel pressure regulator... Your fuel pressure seems to be within specifications, except for possibly the regulator is not increasing the pressure fast enough to prevent a bog from idle? It can be tested using a vacuum pump and a guage... And a Google search for the proper procedure, of course.
Same goes for the TPS. It can be easily tested using a multimeter.
Other than that, you've pretty much covered the engine management diagnosis. I suppose that next would be a compression/leakdown test to determine the internal health of the engine.
Old 11-29-2017, 07:27 PM   #17
Revvv's Avatar
Straybullitt is spot on.
Old 11-29-2017, 07:42 PM   #18
Also, not sure on your Mustang, but when I deleted the air pump on my truck, there was a vacuum hose that needed to be plugged. I assume that there are no open vacuum lines causing a leak on your machine?
Old 11-29-2017, 07:48 PM   #19
I wish that I was spot on enough to be able to say "You just need to oil up the return spring on the thingamajobber. That'll take care of it!"
Old 11-30-2017, 05:41 AM   #20
Mr.Five0's Avatar
I know the TPS voltage should be below 1 volt, need to test, I had done compression test on all cylinders like a month before illness started, all good almost identical. Thanks for the pressure regulator tip, I did add a baseline regulator when ATI was installed back in 95 maybe its bad,or OEM is bad... keep you all posted. thanks again
Old 11-30-2017, 05:51 AM   #21
Mr.Five0's Avatar
Thanks ...had performed smoke test for vacuum leaks, found bladder in EGR had slight leak, replaced. yes line from pump plugged..
Old 12-04-2017, 07:43 AM   #22
Mr.Five0's Avatar
Case of the Missing diaphragm
Good morning gents, so I decided to order a new adjustable fuel pressure regulator from LMR arrives today, in the meantime I proceeded to remove and disassemble my 1994, 24 year old adj. regulator and VUALA!!
where the diaphragm is supposed to be are only slight remnants of what looks like residue from a white medical glove..I will be sitting in my driveway all day bird dogging the mail man arriving with my new regulator.more to follow!!
Name:	no bladder.jpg
Old 12-04-2017, 07:48 AM   #23
Revvv's Avatar
That will definitely cause a problem. Hopefully that is the last little part of your puzzle.
Old 12-06-2017, 11:27 AM   #24
Mr.Five0's Avatar
BOYCOTT USPS THEY SUCK!! So USPS lost my fuel pressure regulator, after traveling to 4 counties in Florida and arguing with idiot so called site managers, I located it this morning in Miramar FL, I went ahead and installed it, adjusted the baseline to 42 PSI, still have same bogging issue. I ordered a OBD1 scanner, I know some guys use jumpers whatever to pull 3 digit codes, I don't get that. I have a brand new OEM Ford TPS in the box, I know should be .97 or less, waiting for friend to come by weekend with good Volt Meter and OBD scanner to arrive from Amazon, did I mention USPS sucks, BOYCOTT!!!!
Old 12-06-2017, 12:55 PM   #25
Revvv's Avatar
You have luck like mine.
Old 12-07-2017, 09:23 AM   #26
IAC
TFI Module
Ignition Coil
Cap Rotor
Distributor
Harmonic Balancer
PCV Valve
It's either your fuel pump or injectors have gone bad! Either that it check your MAF to see if its been damaged some how!
msp.ecoboost is offline   Reply With Quote
Old 12-07-2017, 01:24 PM   #27
Revvv's Avatar
The question now is; "What have you NOT replaced on the car"?
Old 12-11-2017, 03:10 PM   #28
Mr.Five0's Avatar
Throwing ib the towel, today I got OBD1 scanner and ran it, got only one code 563 Fan circuit fault, which does not make sense because the 1st thing scanner does is run electric fan, works fine. Going to try and limp car to an old school mechanic 15 miles from home, I did find another post guy with similar problem was the sock on OEM fuel pump in tank disintegrated and was causing this issue, I will post final resolution.
Old 12-11-2017, 10:09 PM   #29
The fan code might be because the fan didn't complete a full cycle, or something like that. Probably doesn't mean anything.
I was hoping that there would be a code to point the diagnosis in the right direction. I still suspect a fuel delivery problem. Have the mechanic test the vacuum signal to the fuel pressure regulator, if he can't find anything obvious that is wrong.
Good luck!
Old 12-11-2017, 10:15 PM   #30
Revvv's Avatar
At the end of this a simple problem will be found. It's always the little things that seem to cause the biggest complication.
Old 12-11-2017, 10:18 PM   #31
Revvv's Avatar
Is the manifold sealing? Is there a crack you have yet to notice.
I agree with Stray that it sounds like a fuel issue, but too much air that isn't monitored will lean the A/F mixture out and the car will not idle correctly.
Check the PVC hoses, and everything that vents into the intake.
Old 01-09-2018, 10:31 AM   #32
Mr.Five0's Avatar
OK Gents the final verdict, some very patient guys at Kovac Automotive in Davie FL, found the following, bad TPS, replaced , after market Dynamod TFI I replaced was defective, replaced with Motorcraft OEM, main fuel line slight leak losing volume although baseline pressure looked good at 50 psi, the VSS went bad along with speedo gear which had basically deteriorated, speed sensor was bad, #DY1205, car back to normal.
2011 Mustang GT bogs at 3k rpm cmlambert8 2011-2014 Mustang GT 23 05-29-2016 07:54 PM
Engine bogs down over 2500 RPM aforceman 1979-1995 Mustang GT 11 07-02-2015 11:32 AM
At the end of my rope with electrical GolgothaAvante Pre-2005 V6 Mustang 8 11-24-2013 02:17 PM
bogs upto 2500 rpm...cam? jduckz5.0 1979-1995 Mustang GT 4 07-14-2013 08:07 AM
car bogs at like 2k rpm :( Rellik Pre-2005 V6 Mustang 11 05-20-2004 06:58 PM
03:56 AM
