Another question, whats the best rear main seal for a 1993 5.0l engine? I dont want any leaks. I put a ford racing one in last time and i pulled the trans recently and i see its seeping oil already! Anyone have an opinion? Thanks in advance.
Sent from my SM-G930P using Mustang Evolution mobile app
The lip of the rear seal can wear a groove on the machined surface of the crankshaft over time, and replacing the seal will help for a short time and then it will begin to leak again.
If your crank does indeed have a slight groove where the lip of the seal makes contact, the best way to repair it, that I am aware of, is to remove the crank from the engine and have a machine shop cut a series of diagonal knurls on the machined seal surface in a direction so that they are constantly trying to pull the oil back inside of the crank case as the crankshaft rotates.
A competent automotive machine shop will know exactly how to do it, and it really works well for a grooved crank.
Of course, the most convenient time to do this would be during an engine rebuild.
Other than that, I am not aware of any repair sleeves, or anything of that nature, for the rear seal, like are available to repair the harmonic balancer.
In most cases, the "press-fit" of the seal O.D. allows room enough to install the seal to a depth appropriate to it's lip riding next to the seal surface groove.
Ok thank you. About a year or two ago i had the lower end rebuilt. They were supposed to check that and repair if necessary. I had told them i had an issue with it. ??
Like the others said if it is worn and has a lip or just not sealing there is a repair sleeve sold that should buy you some time. I have used it with success a couple of time on some other cars. It is also not to expensive like 50 bucks. Also make sure that is where the leak is from.
Ok. Thank you. One more thing, whats peoples opinion on a ford racing rear main seal or a fel pro teflon one? The felpro is about $30 more - why? Is it that much better?
Get the Ford one. They'll both leak lol. If its just seeping that's normal. Any 5.0 I used to have would have a tiny wet spot of oil in the driveway if it sat a few days. If its not leaking... its empty. Just check the oil level every weekend and top off if needed.
Gotta disagree with you, sorry. I worked for many years in the sealing industry, and learned that for every case of inability to seal a rotating shaft assembly, there could be traced a fault causing it. Leakage is not "acceptable".
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
