95' Cobra SVT Problems - Page 2 - Mustang Evolution
Old 03-15-2009, 10:05 PM   #36
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: 95' Cobra SVT Problems
just a side question, did anyone ever get to you about the engine revving to 2k between shifts? my 94 gt does this and someone else car did to, just curious if anyone had an answer.
glad to see your car is rising once again, don't give up.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 03-16-2009, 12:05 PM   #37
xspektrex's Avatar
Send a message via AIM to xspektrex Send a message via MSN to xspektrex Send a message via Yahoo to xspektrex
my car hasn't run in about 7 months! but i did learn that the TPS(throttle position sensor) was bad and was causing my rev problem
1988 Mustang LX Conversion
*MSD-Ignition*H-Pipe*Shortie BBK Headers*40-Series Flowies*8.8" Rear*3.27 Gears*C4*Stock T-Handle*
xspektrex is offline   Reply With Quote
Old 03-17-2009, 12:19 AM   #38
Region: Oregon
i thought it broke in February... sorry to hear about that, i read you fixed a lot, any more progress?
Old 03-17-2009, 10:32 AM   #39
Titus Wadicus
svtlx's Avatar
hay, how are you coming on your stang? has anyone called you or p.m.'d you with the help you need? let me know and i will p.m. you my phone #, i have free long distance if it is an issue. and i can walk you thru some of the issues you are having if someone else here hasnt helped you or you weren't able to source local help. i wouldnt be were im at had someone not helped me. so let me know, and i will be more than happy to help you with as much as i can.
Old 03-17-2009, 12:07 PM   #40
xspektrex's Avatar
car is "running" now. However, when putting engine back in i forgot to check the oil pump drive shaft (fell out) and i ran the engine till just a lil over 'C' (temp). I'm pretty sure i spun some if not all of the rod bearings. I'm not real sure kuz the damn thing is so loud i can't reall hear anything in the oil-pan area. Puffin lots of thick white smoke too; but i'm sure thats a combination of timing and the remaining oil/rad. fluid in the pipes from the last engine that blew (piston through wall). The car sounds great, has instant throttle response and no knocking (like pushrod hitting valve cover) like the other. So basically at this point i'm going to have to burn more of the "crap" outta the exhaust so i can tune with mind and ear.
P.S - Equal amounts of thick white smoke out both pipes with equal pressure so no compression loss!! YEy
Old 04-27-2009, 08:16 PM   #41
xspektrex's Avatar
yey, time fo mo help gents...
rebuilt engine has TFSI cam with that being the only mod...do not know wether or not the cam was degreed when i got it. do know that i had to put the cam sprocket and crank balancer on.
had the car running for about an hour idling normally.
from behind the car was pushing stoutly from the left pipe and noticably less stout from the right pipe...
after about an hour the i got the godawful clinking sound.
tore er' dowon to find a busted spring and dropped valve on cylinder 6...
had her tested for compression afterwards and she passed....
also had a camera ran into the cylinder to check things out and that passed...
before i put a new set of springs on i want to run down some specs/ ask stuff
current parts
-1.6 GT roller rockers (stamped steel; i know!!! all i could afford at time)
-stock push-rods
-stock lifters
-single coil valve springs
-gt40 heads (cobra original)
-stock upper/lower (cobra original)
with these things in mind i was curious to the push-rod length i should be using and wether or not this TFSI is the culprat of doom.
I believe I Can:
use the TFSI with the GT40's
use 6.25(in) push-rods
use 1.6 Roller-Rockers (1.7's cause clearance issues)
and NEED dual coil valve springs with maximum diameter of 1.55(in)
I have to buy parts this week so please grind your mind!!!
Old 01-19-2011, 11:16 AM   #42
MC770's Avatar
Layla...... Time to use your new power....
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-19-2011, 11:21 AM   #43
Titus Wadicus
svtlx's Avatar
+1...this is te 2nd time this idiot has posted
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-19-2011, 11:42 AM   #44
Banned, deleted, closed.
svt
95' SVT Cobra xspektrex 1979-1995 Mustang GT 29 03-15-2009 09:40 PM
Cobra-r Front, Cobra Spoiler, C-Scoops, for my 95' stang?? Should I buy them? xtrememustang1 Mustang Audio & Video 12 07-29-2004 08:31 PM
12:31 AM
