Fox body with SN95 headers.... - Mustang Evolution
Old 01-17-2004, 10:25 PM   #1
Tbird232ci's Avatar
Im thinkin about slapping some stock V6 headers on my bird, and using a stock h-pipe from a fox body stang...does anyone know if itll work?
Old 01-17-2004, 10:43 PM   #2
tire's Avatar
Send a message via AIM to tire
i sold my 00 v6 exhaust manifolds to a tbird owner. i can't provide any more information than that, sorry.
tire is offline   Reply With Quote
Old 01-18-2004, 09:37 AM   #3
I used stock 94-98 v6 headers on my fox 83 stang and I used a 99v6 h pipe.
In hindsight that was dumb. I should have stuck with a true fox 5.0 h-pipe. I had
transmission crossmember clearance issues because of that H. You should have
better luck with a fox H
-Mik
Redlined Performance Mustangs
Cylinder Head / Intake Porting, Camshafts, Pistons, Cold Airs/Pulleys
www.rpm-mustangs.com
http://rpm-mustangs.com/pictures/KEcrank.jpg
mikael is offline   Reply With Quote
Old 01-18-2004, 07:01 PM   #4
Tbird232ci's Avatar
wow, so the collectors should line up with the fox 5.0 h-pipe?
Old 01-18-2004, 07:34 PM   #5
Rick0636's Avatar
Mikael would know if anyone would!
Old 01-18-2004, 08:19 PM   #6
Dom
Dom's Avatar
Send a message via AIM to Dom
They'll work, you just gotta make 'em fit. :yes:
Old 01-18-2004, 11:44 PM   #7
A friend with a 96v6 mustang used a fox 5.0 h-pipe. I've known of one
other guy who did it too. It's not a perfect fit but it's close enough to work.
-Mik
Old 01-19-2004, 09:36 AM   #8
Tbird232ci's Avatar
so just crank down on those collector bolts so they seal, then pull out the jack to get it close to the undercarriege eh?
thanks for the help man, everyone else just guesses and assumes
Old 01-19-2004, 09:45 AM   #9
Assuming makes an *** outta U and me.
Lift up the center section of the H and tighten the collector studs/nuts and
watch where it pulls it. Try to guide it if you can. Clamp the h-pipe
together lightly. Once everything is in place, put some heavy spot welds
on the seam of the H where the two sides come together. Drop everything
and seam weld it, then throw it back on. Muffler clamps are geh toe and
always end up leaking. I've had a few customers come in needing that
welded up because it leaked, then they clamped it more and it leaked
more.
Good luck!
-Mik
Old 01-19-2004, 06:11 PM   #10
Tbird232ci's Avatar
so i might have a bit of trouble with a stock HO pipe since it is one piece so-to-speak
Old 01-19-2004, 09:18 PM   #11
Send a message via Yahoo to plstktnkr2
exhaust question
Why not run longtube MAC headers? they are made for thr SN95 body so fitting the bird should be easy. I will be running a set on my 4.2 conversion in my 83 stang conv and they look like they will fit
just asking
rick
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 01-19-2004, 11:42 PM   #12
Dom
Dom's Avatar
Different headers on a V6 is wierd. More Flow = Less HP. Everyone else is trying to reduce backpressure while we're trying to gain it.
Old 01-20-2004, 07:35 PM   #13
Tbird232ci's Avatar
Re: exhaust question
just asking
rick
the 3.8L in my car isnt gonna stay, the 87 has CFI, and a whopping 120hp, trying to push 3600 pounds...
plus they cost too much, when i can get a set of 5.0 headers for 120
Old 01-23-2004, 07:56 AM   #14
well for your application you may be right but with added airflow from larger valves for mine they should be ok,btw I have a set of stock headers when engine is dyno'ed i will try both to see which is best
[SIGPIC][/SIGP
Old 01-24-2004, 03:32 PM   #15
Tbird232ci's Avatar
sharpsburg eh? i dont know where its at, but you might know where im at, you know where Severn is? right outside of Ft Meade?
Old 02-03-2004, 09:38 AM   #16
Yes t-bird232 been there a time or two, I am 30 miles west of Fredneck 10 south of Hagerstown on rt 65 about hour and half or a lil less from you . your off of 100. Maybe we hook up sometime when car is done and have a beer or whatever
used to have a '88 bird, rootbeer brown with 3.8 ,she was no racecar lol
[SIGPIC][/SIGP
Old 02-03-2004, 07:09 PM   #17
Rick0636's Avatar
Well, I just got back from Gaithersburg and those headers are still in my trunk man!!
fox body
Another Fox body newbie 74H1E New Member Introductions & Greetings 4 05-09-2009 08:02 AM
who has put sn95 seats in a fox? svtlx 1979-1995 Mustang GT 8 04-22-2007 08:14 PM
For all the Fox Body people... Cajun JungleBoy Pictures and Videos 8 02-20-2007 02:29 PM
Fox 8.8 into a sn95 Roadhawg Pre-2005 V6 Mustang 12 11-21-2005 03:05 PM
SN95 Saleen Body Kit Question? How to Prevent the ) Look KrazyPony Mustang Audio & Video 3 07-27-2003 09:06 PM
11:23 PM
