1990 mustang 5.0 not wanting to run - Mustang Evolution
Old 08-31-2008, 11:45 AM   #1
the only way to get the car to start is hold the throttle wide open if you you let off it stalls there is no in between full throttle nothing at all.
Big Pete is offline   Reply With Quote
Old 10-24-2008, 02:14 PM   #2
Re: 1990 mustang 5.0 not wanting to run
what your fuel pressure. check vacuum. fire ect.. need more info
bubbafinch is offline   Reply With Quote
Old 10-27-2008, 12:08 PM   #3
1234's Avatar
Sounds like a fuel problem. Could be anything stated above.
Old 01-24-2009, 03:17 AM   #4
When you try to start the car when your parked if you Hold the Throttle Wide open and the car starts does it keep on running smoothly or does it die after it starts?If It dies it sounds like a Fuel pressure regulator problem if it keeps on running and drives fine afterwards sounds like you have big injectors and its not tuned right or your MAF may not be calibrated to the Injectors perfectly.
When you have to hold the gas petal Wide open that makes the computer shut off all fuel going thru the injectors thus leaning the mixture out if the car WAS flooded.That cleans out the Overly rich mixture till it starts.Alot of guys have this problem when running 42# injectors and higher if their cars arent tuned for them especially in Hot weather its called Hot Starts.
S-Trimmed302 is offline   Reply With Quote
Old 01-24-2009, 09:49 AM   #5
hottcobra's Avatar
it's for sure a fuel issue
Old 02-01-2009, 08:07 AM   #6
Titus Wadicus
svtlx's Avatar
sooo, is your car stock? if not, i think we need to know wut heads and "compression", cam, adj. fuel pressure regulator or not, current fuel pressure, injector size, mass air meter size and calibration. i think sum of this info would us help u more efficiently and reduce guesses.
Old 02-01-2009, 09:15 AM   #7
hottcobra's Avatar
thread is 6 months old
1990 mustang
Wanting to Upgrade Mustang OIF2009Mustang Pre-2005 V6 Mustang 10 05-24-2009 12:23 PM
Evals Mustang Update (for everyone wanting/wondering!) *PICS Autobadges.com The Bar 48 08-22-2003 01:48 PM
07:43 PM
