how the heck does a turbo work? - Mustang Evolution
Old 03-03-2004, 09:37 AM   #1
Zim
You want to **** me?
Zim's Avatar
i see all these pictures of turbos connected to headers and things like that, but i have no idea how theyre set up. is dual exhaust worthless after a turbo or what the heck is the deal... somone explain how theyre set up for me so i understand this.
I like toys
Old 03-03-2004, 09:55 AM   #2
Monkey's Avatar
turbos work by compressing the exhaust air. they are bolted to the header because that is the shortest distance for the exhaust to flow. the exhaust comes in and spins the turbine which compresses the air. then it is pushed out and into the upper intercooler piping into the intercooler. then passes into more piping into the throttle body. there is a wastegate on them that when you shift or are at max boost, it will bleed off some of the air into the downpipe. to get technical, there is a recirculating and an atomospheric blow off valve. both release air from in the piping if boost is too high. keeps it at Xpsi. the downpipe is basically the new header. its usually about 3" in diameter becuase its easier to run single exhaust with it. however, you can use a reverse y-pipe and make it run duals if you really wanted to.
here is a pic i borrowed from www.boost-solutions.com. is shows the basic look of a turbo. you can see in the backgroud a flang. that is hooked up to the exhaust manifold. it is then spun and compressed with fresh air (from the impellor side) and then passed to the outlet pipe which is facing 3 o'clock. behind the impeller side, is where the downpipe comes off of
also, check out www.howstuffworks.com for more detailed info with better pics
Old 03-03-2004, 09:59 AM   #3
they need to make turbos for mustangs. I would take one over a SC anyday.
Old 03-03-2004, 10:06 AM   #4
tire's Avatar
Send a message via AIM to tire
they are about to. proturbokits already does, with more coming afterwards.
tire is offline   Reply With Quote
Old 03-03-2004, 10:07 AM   #5
awesome, better start saving my pennies
Old 03-03-2004, 10:09 AM   #6
Monkey's Avatar
proturbo does NOT make a kit for the stang anymore. they had horrible welds, even worse tuning, and the prototype car blew its engine. plans to start selling turbo kits are out there but only by individual people so it takes a while for them to build them
Old 03-03-2004, 10:10 AM   #7
tire's Avatar
the reason why the test kit car got fubared was because xavier was a dumbass and broke contract by upping the boost to at least 13-14psi. i wasn't aware they stopped making them.
Old 03-03-2004, 10:16 AM   #8
Monkey's Avatar
no one else i have heard of still sells the PTK kit. and no one on any board i have read on has bought one. so i would avoid them like the plague.
Old 03-06-2004, 04:07 PM   #9
speedpenguin's Avatar
the exhaust gasses sping the fan blade inside the exhaust side housing, which is connected to the intake or blower side. With more stress, the engine puts out more gasses, making the wheel spin faster, compressing the intake air, causing boost. The fan sizes and housing sizes affect how much boost is made how quickly, on either side of the turbo.
speedpenguin is offline   Reply With Quote
Old 03-06-2004, 05:46 PM   #10
Seph's Avatar
doesn't turbo kits kill engines tho? who told me that..
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 03-06-2004, 05:55 PM   #11
Dom
Dom's Avatar
Send a message via AIM to Dom
Not if you do it right.
Zim, here are some pictures of a turbo on a 99-04 V6.
Old 03-06-2004, 06:08 PM   #12
Seph's Avatar
WHAT A DIRTY CAR! lol
-Patrick
Old 03-06-2004, 06:34 PM   #13
Region: New Hampshire
Send a message via AIM to Smokedya95stang
lol, justin had a twin turbo set up he made, then sold it, he ran a 11.88 or something like that.
I think he's making a new setup.
-Charles
Smokedya95stang is offline   Reply With Quote
What the heck!? braumab The Bar 6 10-29-2008 12:11 PM
Here's a pimp as heck v6 powered shopping cart I caught ... MonteCitan Pictures and Videos 18 05-18-2007 06:25 AM
What in the heck. lowflyn The Bar 20 06-04-2005 06:41 AM
What the heck is this? lowflyn The Bar 7 12-07-2004 03:49 PM
What the heck are reputation points?! Zim The Bar 15 03-20-2004 04:09 PM
11:06 PM
