fuel pump?? - Mustang Evolution
Old 09-26-2008, 11:21 PM   #1
fuel pump??
Sometimes from a stop ill go to take off and my car will go but then bog down and almost stalls but it stays running (barely)and if I put my foot on the gas it wont rev or anything but its still on and then all of a sudden it will kick in and all is good again , any help will be greatly appreciated.
Xx_1990GT_xX is offline   Reply With Quote
Old 09-27-2008, 10:09 AM   #2
1234's Avatar
Re: fuel pump??
Could be a number of different things. Could be fuel pump, throttle position sensor, erg position sensor. I would start by checking the fuel pressure. Is it throwing any codes?
Old 09-27-2008, 10:35 AM   #3
Re: fuel pump??
if it does it a WOT then its not egr related, but fuel pressure should be checked first, dirty mass air is something to look at too
SimplyOrange is offline   Reply With Quote
Old 09-27-2008, 01:49 PM   #4
Re: fuel pump??
I cleaned the maf the first time this happened and it still does it . the CEL never comes on when this happens and i dont own a scanner to see if anything shows up on the comp. Ill have toi ready my hanes /chilton manuals to see about the TPS and the egr sensor
Old 09-27-2008, 02:00 PM   #5
Re: fuel pump??
Thanks yall
Old 10-04-2008, 01:26 PM   #6
silverstangboy's Avatar
Re: fuel pump??
don't need a code scanner, comes built into the car
DIY KOEO/KOER/Cylinder Balance Self-Test Procedure
93 mustang notch
~450hp 331 stroker - Sold
Old 10-07-2008, 02:06 AM   #7
Re: fuel pump??
hey bud...i would start with getting rid of your fuel pump and putting an aftermarket inline fuel pump in...and a pressure regulater.....it could be some vapor lock...
RICKKK247 is offline   Reply With Quote
Old 10-07-2008, 06:37 AM   #8
Re: fuel pump??
throttle position sensors are common issues with the 5.0, u could try to adjust it or check its voltage. the repair manuals have more info on this.
96 GT- Who knows what's in it.
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
fuel pump for v6 The Darkside Pre-2005 V6 Mustang 11 01-06-2009 09:27 PM
Fuel pump lowflyn Mustang Parts for Sale and Wanted 4 08-01-2006 08:12 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
08:53 AM
