Setup Feedback - Mustang Evolution
Old 04-05-2004, 01:19 PM   #1
Tbird232ci's Avatar
Setup Feedback
alright, i just want a little feedback/power estimates and tips and whatnot on the setup i plan on running
-starting with a 88 standard output, putting in HO pistons and rods, new bearings, re-ring, and a double roller timing set
-trick flow stage 1 cam (can get the specs if desired, its similar to an E303, but with more exhaust lift and duration)
-E7TE heads, stock valves, probably gasket matching the exhaust ports, and cleaning the intake side a bit, with trick flow springs, locks and retainers
-stock HO intake manifold with a phenolic spacer(most likely a temporary item)
-stock HO throttle body half shafted and smoothed out
-19# injectors
-70mm MAF from a 94+ mn12
-stock fuel pump untill i can afford a new one
-stock ignition
-u/d crankshaft pulley, the power steering, a/c and smog pump will be ditched
-egr, emmissions, and all that crap will be gone
-flowtech long tube headers, probably gonna run 2.5" xhaust out the sides, maybe ill run mufflers
-electric fan
as for drivetrain, im probably going to use a 4cylinder T5 for break in, and an OE replacement clutch, so i can save up to get a decent T5 for a 5.0, and my rear is currently an open 7.5 with 3.27's
Old 04-05-2004, 07:28 PM   #2
Rick0636's Avatar
How you going to get through emissions inspection like that?
Old 04-05-2004, 11:07 PM   #3
Tbird232ci's Avatar
as long as the engine is running good and clean, there wont be any problems, and i only have to worry about it once every 2 years
the only thing they ask for is cats, and full exhaust, which with long tube headers, exhaust swapping isnt terribly hard
Old 04-08-2004, 11:03 AM   #4
Tbird232ci's Avatar
anybody? hmm
Old 04-12-2004, 10:19 AM   #5
Those mods should put you at about 220-240rwhp...
Not bad beginning mods for a 302..
-Smoke
1990 Mustang GT-
347 Stroker-Tremec 3550-Compucar Nitrous, AFR, Systemax Intake, AFM, 30lbers, 70MM TB, 76mm MAF, full suspension and lots more
1995 Chevy S-10
406 SBC, Dual tunnel ram, Dart heads, Nitrous, full tub, 4-link, adjustable drag shocks, coil-overs, 9in rearend, 4.56 gears...etc
Click here to visit the my webpage
Smokedawg is offline   Reply With Quote
Old 04-12-2004, 02:17 PM   #6
Tbird232ci's Avatar
not too bad, so that should be roughly 250-270 at the flywheel, and definatly more room to build
wouldnt do too bad motivating this car, especially with a 5-speed
Old 07-04-2004, 02:32 PM   #7
Or just take a trip down to NC and buy my 88GT 5.0 HO motor
$350 and just install your intake and you be having 225 instantly
Jayber is offline   Reply With Quote
Old 07-04-2004, 09:43 PM   #8
Tbird232ci's Avatar
haha, for 350, i could probably have the 5.0 i have sitting in my car and just abour running
i have connections on the brackets, wiring harness and all that good stuff, just need a MAF computer
Old 07-04-2004, 09:47 PM   #9
Tbird232ci's Avatar
also, i decided, im keeping the power steering, and since my longtubes supposivly clear the AOD, ill be running the automatic for a while
emissions and EGR are still getting ditched
Feedback on vBulletin 4.0 Brent The Bar 8 10-25-2009 08:46 PM
need some feedback on maybe buying this KustomSaturn The Bar 3 03-11-2009 05:36 PM
New Style Feedback Brent ME Site Help & Announcements 41 04-02-2008 05:35 PM
New Forum Layout **Feedback** Brent ME Site Help & Announcements 11 08-20-2005 01:20 PM
Need Feedback. chavez630 Mustang Audio & Video 17 10-16-2004 06:45 PM
09:46 PM
