Passenger side power window motor replacement - Mustang Evolution
Old 10-16-2008, 01:08 PM   #1
Have only done this procedure once before in my life and that was on an old Dodge van...but here goes. Motor gets power but sounds like drive gear stripped. Can the motor be replaced without removing regulator linkage? I don't really want to deal with that danged spring. OBTW this is on '95 GT (the wifes baby) she's had since new.
jaykay is offline   Reply With Quote
Old 10-18-2008, 02:40 PM   #2
Re: Passenger side power window motor replacement
Memo to self...
No you don't, just remove the three screws staring at you, loosen up the regulator a bit and remove the motor. Remove the sheet metal grease retainer, remove drive gear, install new torque clips, grease 'er up, lube your slides, reinstall, rock and roll.
Rear Passenger power window motor failure drnelsen 1996-2004 Mustang GT 5 06-26-2009 08:08 PM
Power window motor Foxone Pre-2005 V6 Mustang 16 02-10-2009 01:56 PM
Passenger Side Power Window Not Working louie7600 General Mustang Discussion 1 07-27-2008 07:36 PM
Power Window Motor Pizon Pre-2005 V6 Mustang 8 05-16-2007 10:19 PM
driver side window motor / switch ? Dark02Pony Pre-2005 V6 Mustang 2 06-21-2005 10:02 PM
01:05 AM
