Gt-40 intake problems - Mustang Evolution
Old 07-14-2004, 11:45 AM   #1
Post Gt-40 intake problems
I own an 87 gt, (non mass air) and recently i installed a gt-40 upper and lower intake, 24lb injectors and bbk 70mm throttle body. Once i got it together and started it up, it was idling at 1800rpms. I noticed that the bottom of the upper gt-40 did not have the same number of hoses as the stock manifold (therefore i had to T some hoses). Muscle mustangs and fast fords article said to transfer the vaccuum tree over to the new intake, but i am confused on how to do this?? Also, the lower gt-40 does not have the required 2: space for the temperature sensor so i have half a sensor just hanging around with nowhere to plug into. I take it that the throttle position sensor is the little screw that you can back out and in, I have backed it completley out and now the car is still idling at 1500? Im not sure what to do, so if any one has done this before and can assist me, please give feedback. Thanks
rossafeller is offline   Reply With Quote
Old 07-14-2004, 08:07 PM   #2
Tbird232ci's Avatar
honestly, i think the idle problem has to do with it being a non MAF car, try putting your stock throttle body on the intake to see how it responds
Old 07-14-2004, 09:25 PM   #3
I put the stock TB on the gt-40 and it acted like it was not getting enough air. It seemed as if there was a huge vaccuum leak, shaking and sputtering. But, this kinda makes sense because i beleive the gt-40 is set up for a 70mm, so a 58mm would prally hurt it...... Tomorrow im going to take it to an expert and see what he says, because im stumped.
Old 07-15-2004, 11:36 PM   #4
Tbird232ci's Avatar
did you get a good seal around the lower intake?
got some problems noslow5ohh 1979-1995 Mustang GT 0 06-05-2008 12:04 PM
87 problems 87lx50 1979-1995 Mustang GT 9 03-18-2007 05:36 PM
more problems charkelly9 Mustang Audio & Video 18 05-19-2005 07:22 PM
More Problems Toxinz The Bar 4 05-01-2004 10:09 PM
Problems: Smokedya95stang ME Site Help & Announcements 0 03-06-2004 06:51 PM
08:08 PM
