Distributor Question - Mustang Evolution
Old 07-19-2004, 09:53 PM   #1
Ok I'm not really a mustang guy but I am a FORD man. I am putting a 92 mustang 5.0 ho engine in a 69 Bronco. I'm not planning on using the efi so I can't use the tfi distributor. Can anyone tell me what distributor I can use with the roller cam? My Bronco is already wired for the duraspark ignition. But here in Idaho nobody knows what distributor to use. Any info would be appreciated. Thanks.
P.S. The motor is a Police Interceptor, If that makes any difference.
fordman is offline   Reply With Quote
Old 07-19-2004, 09:57 PM   #2
fast64's Avatar
are you sure the distributors are different, or that you cant use the efi distributor with a carb?
GO BRAVES
Old 07-19-2004, 10:07 PM   #3
The tfi distributor is only for efi. Will not work with a carb. No computer to hook it up
Old 07-20-2004, 12:57 PM   #4
You can run any regular Duraspark compatable dizzy. Just make sure you put on the correct drive gear.
Just remove the dizzy gear from the TFI one and put it on the Dura model.
Or just go down to AutoZone and get a replacement dizzy for an 85 Mustang GT with 4bbl. NOT the CFI model as it isnt a roller cam motor. Make sure its the 4bbl model.
Jayber is offline   Reply With Quote
f**** distributor removal help forcedfed1 1979-1995 Mustang GT 6 11-20-2009 12:58 PM
04:12 AM
