68 Mustang - Mustang Evolution
Old 07-21-2004, 09:21 AM   #1
68 Mustang
Hey guys , i have a 68 mustang and want to know if i can put a Latemodel Motor in it. Most of the High performance motors you can buy all come with serpantine belts and what not. I know for a fact my altenator is a 3 wire set up and i am not sure if the alt for a late model is 1 or 3 peice wire.
Is there a chance i could use a late model motor in my early model car ?
Thanks
Scott
Static is offline   Reply With Quote
Old 07-21-2004, 09:31 AM   #2
fast64's Avatar
it can be done and its not very hard. I am going to be putting an efi 5.0 and a t-5 in my 64 1/2 in the coming months. do you plan on carburating the late model motor or having fuel injection?
GO BRAVES
Old 07-21-2004, 09:50 AM   #3
Carb. Do i need a 3 wire to 1 wire conversion for a late model Altenator ? or do they make a 3 wire version ? Will i need a Early Model Oil pan or latemodel ?
Old 07-21-2004, 09:50 AM   #4
sorry if i seem stupid , i just cant find any info on this @ all
Old 07-21-2004, 09:57 AM   #5
fast64's Avatar
i'm not sure about the alt. but you will have to get a oil pan and pickup from a 68. you also have to get an adapter for the transmission as the early transmissions are 5 bolt and the late model are 6 bolt. check out www.corral.net/forums alot of guys there have done late model engine and/or transmission swaps
GO BRAVES
Old 07-21-2004, 10:04 AM   #6
I knew about the tranny , going to put a TCI Street Fighter in they said it would fit and work fine with a late model.
Hopefully some one knows about the altenator
Old 08-02-2004, 02:09 PM   #7
Bane-'s Avatar
Im going to be doing this myself soon also hopefully, found a 67 for $450 (not in showroom shape but not far enough gone to be scraped) im gonna get that park it in yard and find a donor foxbody for motor and stuff. only thing im wondering is if the older foxbodies had hydraulic clutches (i dont want to have to wear a concrete shoe to push in clutch :-p)
Old 08-02-2004, 05:01 PM   #8
No hydra clutch in the Mustangs.
Jayber is offline   Reply With Quote
Old 08-03-2004, 08:56 AM   #9
Bane-'s Avatar
what i meant was try pushing a clutch of a 60's and try pushing a clutch of todays mustangs, no comparision I dont want driving to wear me out to have it feel like i ust lifted the car with my legs lol
04:05 AM
