NO SPARK - Mustang Evolution
Old 01-08-2009, 02:58 PM   #1
NO SPARK
1990 mustang 5.0 weak spark at coil no spark at plug new plugs,dist.cap rotor button ,coil module, wires. Ohm out module check all voltages ,grn. Still no spark at plugs weak spark with dist. To coil lead grounded
KEYSVILLEDAVE is offline   Reply With Quote
Old 01-08-2009, 03:06 PM   #2
hottcobra's Avatar
Re: NO SPARK
did you ohm your ground wire, or just check with test light?
Old 01-08-2009, 09:06 PM   #3
1234's Avatar
Re: NO SPARK
What about the pickup in the distributer?
Old 01-09-2009, 03:07 PM   #4
Herbstang's Avatar
Re: NO SPARK
Bad secondary power ground ,loose computer power ground , Bad EEC relay what color is the spark? a bright orange indicated a weak spark. blue orange means a good spark. a blue white spark knocks you ON YOUR ***
Spark Plugs drkchocolate07 Pre-2005 V6 Mustang 9 05-10-2009 01:29 PM
Which spark plugs should I use??? koch_A_tyler 1996-2004 Mustang GT 5 03-18-2008 06:36 AM
Not getting any spark 92gtny 1979-1995 Mustang GT 6 01-12-2008 03:51 PM
Spark Plugs megax29 Pre-2005 V6 Mustang 13 03-25-2006 07:51 AM
Spark Plugs Stang01 Pre-2005 V6 Mustang 19 07-18-2003 04:55 PM
07:51 AM
