estimate horsepower at the crank an at the wheel - Mustang Evolution
Old 01-20-2009, 10:54 AM   #1
Smile estimate horsepower at the crank an at the wheel
i have a 88 mustang 5.0
bbk shorty headers
bbk h pipe
holy systen max intake manaful top an bottom
3.73 gears
msd ignotion full set up
electric fan
f303 cam
juced302 is offline   Reply With Quote
Old 01-20-2009, 11:11 AM   #2
MonteCitan's Avatar
Re: estimate horsepower at the crank an at the wheel
Seeing as you've still got stock heads... I had basically the same work done, but GT40 tubular upper/lower on my 89 5.0, shorty headers, 3.55 gears, stock ignition, stock fan, e303 cam.. and ran 13.7s, if I had to guess I'd say you're around 225-250 wheel HP with a manual, up to 240ish with an auto.. I could be quite wrong, though, it's been known to happen
Ever run it at the track? And all those estimates changed dramatically if you are 'juiced' also
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-20-2009, 03:08 PM   #3
dont DARE install a cam with out heads/intakes to go with it and there are better options than the e303
Old 01-20-2009, 03:19 PM   #4
MonteCitan's Avatar
Actually it helped out a LOT at the track, lost some midrange but was able to shift at 5800 RPM rather than 5400 RPM at the track.. definitely made a difference - plus I was in there anyhow when my timing chain had jumped, and both of us have/had upper lower intakes with cam...
Old 01-20-2009, 11:30 PM   #5
iwannagofast's Avatar
1000 at the crank, 850ish at the wheels
iwannagofast is offline   Reply With Quote
Old 01-21-2009, 07:30 AM   #6
^^ well I mean why do all the word when you can swap on heads/intakes for about the same effort.
Old 01-21-2009, 08:00 AM   #7
MonteCitan's Avatar
Because a good set of heads can run over $1000.. that's not always an option for people just starting out...
Old 02-01-2009, 08:36 AM   #8
Titus Wadicus
svtlx's Avatar
this is so true. he could port his "e7's" if money is a real issue. you can squeeze close to 40hp out e7's with stock valves. this is very beneficial if you are tryn to save up for a blower or turbo. and it would leave a few dollars on the table to upgrade injectors and get a adj. fuel pressure regulator. cause he will definatley need it if the heads are correctly ported. just my 2 cents
Old 03-05-2009, 11:37 AM   #9
thanks
Front Bumper Estimate jwalthersoccer Pre-2005 V6 Mustang 29 01-12-2010 10:08 AM
Horsepower estimate please upton7 1996-2004 Mustang GT 6 12-15-2009 08:59 AM
estimate plz upton7 General Mustang Discussion 4 04-03-2009 02:36 PM
Estimate using MPH... Stang_1973 Pre-2005 V6 Mustang 6 12-16-2004 07:59 AM
got an estimate today *advice desired* dark The Bar 8 09-25-2004 04:50 PM
02:35 PM
