help - Mustang Evolution
Old 01-22-2009, 12:54 PM   #1
help
wat other cam then the f303 is beter but with out touching my pistons
juced302 is offline   Reply With Quote
Old 01-22-2009, 02:30 PM   #2
Scut95's Avatar
Re: help
E303 is ok. Basically if you go on comp or crane cams they will list all the cams available for your car and it usually has a note talking about clearance if you need to be careful. A good option is talk to a tech rep for one of those companies and tell him/her what your plans for the car are, your current mods, etc and he can tell you a good cam for your app.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 01-23-2009, 05:40 AM   #3
bbunt302's Avatar
Re: help
After looking at your mods in another thread, just about any cam out there is going to be better for your car than a F303. The F303 is intended more for blower applications.
With the stock heads, you do not need anything far from the stock cam. The stock cam is actually quite a good cam until you really start moving more air. However, if you really are dead set on swapping out it out...
I would recommend the Comp Cams XE264:
1500-5500 power band
264/270
.512/.512
114* LSA
But beware! You will need to upgrade your valve springs on the stock heads! These XE cams have extremely quick ramp rates, which plays a big part in how they make good power throughout the power band. But worn out stock valve springs on one of these guys is not a good idea.
The Crane Powermax 2030 is another popular choice for mildly modified Mustangs that won't be quite so hard on the valve springs. It is proven to be a good cam for set-ups similar to yours.
The BEST choice would be to decide on where you want the car to end up before you waste money on a cam. If you are looking at changing the heads out, the cam you buy now will probably be terrible then (or vice versa). The cam should always be the last part you buy. Decide on your heads, intake, gears, etc. and then select a cam that will maximize the potential of all the other parts.
Last but not least, when you are ready to buy a cam, call a custom cam grinder. They can set you up with a grind that will work way better than just some randomly selected OTS cam. You may pay a little more, but the cam is without question one of the most important players in making power. It is not the place to be cheap.
Scary stuff.
Old 01-23-2009, 11:10 AM   #4
Re: help
were can i get of hold of dis comp cam XE264. i mostly order everything from sumit racing
Old 01-23-2009, 11:26 AM   #5
hottcobra's Avatar
Re: help
you can get it from Summit racing
04:32 PM
