msd ignition ****** - Mustang Evolution
Old 09-13-2004, 11:21 AM   #1
theglory's Avatar
msd ignition ******
Hey guys, I have a blown 1988, 302. It has a msd ignition ****** on it that the guy who owned it before me installed. I raced a hemi truck yesterday and looked back and noticed black smoke coming out everywhere. I know thats just too much fuel, but i was wondering how do you adjust the timing. How do you know which way to go on it and how far do you adjust it. thanks for the help.
theglory is offline   Reply With Quote
Old 09-15-2004, 09:28 PM   #2
Tbird232ci's Avatar
honestly, ignition ****** isnt going to make your car run overly rich
are you 100% sure its too much fuel? if it is, check the fuel pressure regulator first off
Old 09-20-2004, 06:16 AM   #3
theglory's Avatar
well i know that my fuel pressure gauge says im running about 6 1/2 psi. Isnt black smoke too much fuel. What else can it be
Old 09-20-2004, 07:55 AM   #4
Tbird232ci's Avatar
6.5psi? carburated?
Old 09-20-2004, 11:06 AM   #5
theglory's Avatar
Yeah its carburated, i just know the needle is about halfway between the 6 and the 7 on the gauge.
Old 09-22-2004, 06:15 AM   #6
theglory's Avatar
Does anyone know about this?
Old 02-24-2005, 10:54 PM   #7
silverstangboy's Avatar
black smoke is rich, bluish purple smoke is oil, white smoke is antifreeze
you have carborator problems, this has nothing to do with fuel pressure.
have someone rebuild your carborator, that is unless you think you can do it yourself.
but before you do that have someone adjust the floats and... all that stuff, I really don't know much about them myselves, just know when they're doing something wrong
93 mustang notch
~450hp 331 stroker - Sold
Old 02-25-2005, 12:21 AM   #8
Tbird232ci's Avatar
too much fuel pressure can cause it to run overly rich, but not in his case
never did find out what carb he has on it, if he has an 850 double pumper on a stock 88 HO, that could be a reason why...
Old 03-01-2005, 09:38 PM   #9
Ponycarman's Avatar
Also depends on how the carb is used, it the carb blow thru or suck thru?
Blow thru's can collapse the floats making them run too high a fuel level and run rich. But I'd assume with only 6.5 psi fuel pressure it is a suck thru setup.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 03-02-2005, 06:34 AM   #10
theglory's Avatar
Hey guys sorry I havent been on here in a while. Yeah the blower is a suck thru setup. The carb sits on top of the blower. The carb is a demon 650 carb. I know its the timing, not the carb. Because the guy I got the car from took it to the track it was blowing black smoke everywhere. He said he adjusted the boost ****** on the dash down a little and it mostly went away.
http://www.mustangevolution.com/foru...ine=1101229075
Just living out the blessings Gods given me, one mile at a time!
So many Struggles, So many Trials, So many reasons for me to Fall, But I have all Strength, And I have all Power, And I will Bury You!
Old 09-17-2005, 12:07 PM   #11
Re: msd ignition ******
install a rich- lean sensor in exhaust and adjust fuel and boost timing to get proper exhaust temps and mixtures
kurt herold is offline   Reply With Quote
Old 09-19-2005, 08:47 AM   #12
A timing problem isnt gonna cause that much smoke. I'm gonna say you have carb issues.
Car: black 1993 Mustang Notchback
Engine: 351w, small cam, Holley 650db carb, stealth intake, AFR185s, Crane 1.6 RR's
Tranny: C4 w/ BTE converter, hardened input shaft, and full manual reverse valvebody
Chassis: Eibach drag launch kit and X2C lower control arms
Times pending
mrpburke is offline   Reply With Quote
MSD ignition help blown347ranger 1979-1995 Mustang GT 12 05-30-2007 04:09 PM
Installing MSD ignition Zim 1979-1995 Mustang GT 14 09-17-2005 11:51 AM
****** or beauty? 99CobraVert The Bar 21 08-24-2005 09:04 PM
Msd Ignition ****** Controller theglory 1979-1995 Mustang GT 4 02-24-2005 10:50 PM
10:10 PM
