5.0l wont idle when cold please help!!!!!! - Mustang Evolution
Old 02-05-2009, 03:17 PM   #1
i have a 1987 Ford mustang GT 5.0L 5spd, it wont idle when its cold, it spudders and dies, i have replaced the Engine Coolant Sensor, and Air Charge Temperture sensor, it has a known good Throttle Position Sensor, and Idle Air Control, its a Speed Density car, and the timing is just fine. It runs fine when it warms up. Any Suggestions???????
19875.0GT is offline   Reply With Quote
Old 02-07-2009, 10:22 AM   #2
Re: 5.0l wont idle when cold please help!!!!!!
ok, I set my TPS at .98 volts, and the IAC is working, it just has a very rough idle, and it wont idle AT ALL when it is cold, i set the timing at 12 degrees of timing. Could it be my ECM or what could it be? PLEASE REPLY!!!!!!!!!!!!!
Old 02-07-2009, 12:41 PM   #3
hottcobra's Avatar
you need to check for vacumn leaks. if it's an intake gasket. when the engine heats up the gasket swells and closes the leak. with the engine cold start it up and while it's running spray WD-40 or brake parts cleaner on all the gasket seams if the idle changes you have found your leak. you the spray to pinpoint the leak
Old 02-08-2009, 04:51 PM   #4
bbunt302's Avatar
Try resetting the idle. Here's how:
1. Disconnect the battery's negative terminal to reset/clear the computer's memory. Leave it disconnected for 30 minutes. WARNING: Whenever removing your battery cables ALWAYS disconnect the negative battery cable first and reconnect it last. Otherwise you could destroy your computer or cause a battery explosion.
2. Disconnect the plug going to your idle motor which is located on the front of your throttle body.
3. Reconnect your battery's negative terminal.
4. Start the engine, and set the idle to the rpm you want with the stop screw on the bottom of the throttle body.
5. Turn off the engine.
6. Reconnect the plug on the idle motor
7. Make sure all accesories (radio, blower motor, a/c, lights, etc) are off and start the engine.
8. Let engine run for two minutes.
9. Turn engine off and wait two minutes then restart engine and let idle for two minutes with all accesories on.
Scary stuff.
Old 02-16-2009, 08:49 PM   #5
Good thinking!
Powerboat is offline   Reply With Quote
Old 02-16-2009, 09:04 PM   #6
hottcobra's Avatar
Originally Posted by Powerboat View Post
Good thinking!
why thank you
Help It Wont Start... kack85 Pre-2005 V6 Mustang 5 07-28-2009 07:14 AM
wont start !!! too fast Pre-2005 V6 Mustang 7 04-24-2009 07:26 AM
wont start???? bluestang1724 1979-1995 Mustang GT 11 01-04-2008 09:10 AM
wont start joezappitella 1979-1995 Mustang GT 5 12-04-2007 08:17 PM
i wont be around for a while Zim The Bar 13 12-24-2003 03:15 PM
05:52 AM
