removing crank pulley... - Mustang Evolution
Old 09-23-2004, 01:31 PM   #1
MonteCitan's Avatar
Any tips on pulling off the crank pulley/ dampener in a driveway? ( '89 5.0 HO) or should I just find a .. pulley puller .. before trying anything else, so as not to risk damage to the engine, myself, or other miscellaneous parts?
Old 09-23-2004, 01:37 PM   #2
I'd buy a pulley puller...if those exist...
Old 09-23-2004, 01:55 PM   #3
MonteCitan's Avatar
I have one.. but it's at work.. all the way at the shore.. and yes they exist.. but they're just called a 'puller' 3 prongs, typically.. run bolts from the 3 prongs into the pulley, then the center of the puller usually has a stud with a landing on the end for using a wrench.. turn the stud, the stud pushes on solid ground, the prongs pull the pulley out as you torque the nut.. and eventually the pulley pops off, if that makes sense to you..
I was just hoping there was some other way of doing it haha..
Old 09-23-2004, 02:00 PM   #4
Zim
You want to **** me?
Zim's Avatar
can you wedge something into the belt to keep it from moving then just use a breaker bar on the bolts of the crank pulley? Thats how i changed mine on my 3.8... dunno if the 5.0 is the same type of deal though
I like toys
Old 09-23-2004, 03:11 PM   #5
MonteCitan's Avatar
I already have all the bolts out, the 4 for the pulley.. and the crank bolt, too.. I can't pull the pulley from the crank.. it's stuck on there good
Old 09-23-2004, 04:42 PM   #6
fast64's Avatar
you can probably borrow one from autozone for free
GO BRAVES
Old 09-23-2004, 05:07 PM   #7
Zim
Zim's Avatar
Hammer Time!!!!!
I like toys
Old 09-27-2004, 05:12 AM   #8
MonteCitan's Avatar
I ended up getting my puller from work.. came right off
my damn timing chain, I have no idea how, I didn't expect what I saw at all.. the timing chain was half off the cam sprocket.. go figure
I had lots of people tell me it couldn't jump time with the double roller setup.. yeah, sure..
Old 09-27-2004, 08:55 AM   #9
Tbird232ci's Avatar
how many miles was on the double roller?
Old 09-27-2004, 01:31 PM   #10
MonteCitan's Avatar
178k
Old 09-27-2004, 09:06 PM   #11
Tbird232ci's Avatar
haha, thats why it jump teeth
Old 10-03-2004, 07:08 AM   #12
stretchy
Jayber is offline   Reply With Quote
Old 02-24-2005, 10:45 PM   #13
silverstangboy's Avatar
lmao :rofl:
the pully your talking about is supposed to come off without using any type of puller, that sucker must have been baked on...
93 mustang notch
~450hp 331 stroker - Sold
Old 02-25-2005, 11:40 AM   #14
MonteCitan's Avatar
Originally Posted by silverstangboy
lmao :rofl:
it was baked on.. I sanded the mating surfaces clean and used antiseize on it.. damn aftermarket pulleys
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-01-2005, 09:35 PM   #15
Ponycarman's Avatar
Thumbs down
Originally Posted by MonteCitan
178k
100k max on any timing chain, they do stretch over time. You are lucky. I've seen timing chains come off and bend valves or punch holes in pistons or both. $$$
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 03-01-2005, 10:48 PM   #16
MonteCitan's Avatar
Steve
my timing chain jumped, but not all the way.. maybe skipped ~2-3 teeth? it came off one set of teeth on the crank sprocket.. (double roller, it was only on the outer set of teeth)
new timing chain + fresh coolant & headers... and ran 13.78@102 some lol..
March underdrive crank pulley Torchred02 1996-2004 Mustang GT 4 01-23-2007 02:09 PM
cant get crank pulley off Thomas91169 1996-2004 Mustang GT 23 03-23-2006 09:25 PM
94-98 Underdrive Crank Pulley dapack69 Mustang Parts for Sale and Wanted 0 09-29-2005 10:09 PM
Removing crank pulley on 87 lx 5.0 5 speed WhiteStang99 1979-1995 Mustang GT 9 08-30-2005 07:59 PM
differences betwen 4.2 and 3.8 crank Pulley? Horse Pre-2005 V6 Mustang 3 07-14-2004 09:24 AM
01:29 AM
