Maybe I Need Blinker Fluid - Mustang Evolution
Old 02-09-2009, 08:01 PM   #1
Lightbulb Maybe I Need Blinker Fluid
JUST KIDDING. give me more props than that....but my blinker really doesnt work wich makes me sad. Its not the fuse I checked that already....I would check the bulbs but ALL my blinkers went out at the same time.....that would be a wiring problem right?
nay's mustang is offline   Reply With Quote
Old 02-09-2009, 08:06 PM   #2
Re: Maybe I Need Blinker Fluid
Turn your blinkers on and tilt the steering wheel up and down and see if you get a connection. You had a problem with your horn so it may be a loose connection in the steering wheel.
Old 02-09-2009, 08:09 PM   #3
jimmy_beaner's Avatar
Region: Iowa
I agree with Brent... even better, you could take apart the wheel and look and see. Or perhaps turn your lights on and pull the bulb out (maybe in the reverse order) and check the voltage coming to the lights.
Old 02-09-2009, 09:27 PM   #4
the turn signal/wiper switch is known to go out in the sn95's i have to change 2 in seperate cars already lol. does your hazards work?
96 GT- Who knows what's in it.
Old 02-09-2009, 09:30 PM   #5
hottcobra's Avatar
when you go to the parks store ask for a multi-function switch
Old 02-09-2009, 10:55 PM   #6
blah....i shoulda got an easy button installed in my mustang!
Old 02-10-2009, 04:50 AM   #7
bbunt302's Avatar
This could be any number of things. When I had this problem on my '90 it turned out to be a loose wire on the back of the harness that the hazards switch plugged into. It could also be the turn signal flasher. It could also be the multifunction switch...
You're just gonna have to get a test light and track it down.
Scary stuff.
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
Dont forget to top off your blinker fluid! sonic04edge The Bar 11 03-01-2009 10:05 AM
My blinker is having a seizure Brent Pre-2005 V6 Mustang 24 05-04-2004 02:02 PM
Timing on my blinker is screwed up Seph Pre-2005 V6 Mustang 6 03-28-2004 10:06 PM
Anyone low on blinker fluid? Smokedawg The Bar 7 02-21-2004 01:07 PM
11:43 PM
