intermittent miss on accel - Mustang Evolution
Old 10-18-2004, 01:31 PM   #1
MonteCitan's Avatar
Well my cars' been sitting ~ 2 months while I did the timing chain
all's back together and it seems to be running okay at idle/revving it up with no load - no leaks/drips/odd noises - timing's set at 12* advance running premium gas..
when driving it.. punching the gas a bit.. its stumbling intermittently, not frequently enough to be a dead miss, but definitely there, it's accelerating, then its not, then accelerating again.. a dead time of sorts
anyone have any ideas what it could be?
I don't have access to my PCED like I usually would
Old 10-19-2004, 11:34 AM   #2
MonteCitan's Avatar
I found I could wobble my distributor cap a little bit side to side.. so I'm gonna replace that, then see where I can go from there.. in the meantime, anyone have any ideas?
Old 10-19-2004, 11:38 AM   #3
Zim
You want to **** me?
Zim's Avatar
are all the plugs gapped right and all still good?
I like toys
Old 10-19-2004, 12:23 PM   #4
MonteCitan's Avatar
should be, I haven't changed them.. though they ran alright til I jumped time..
Old 10-19-2004, 04:08 PM   #5
fast64's Avatar
check your plugs and wires then, always try to fix the simple first!
GO BRAVES
Old 08-28-2006, 08:29 AM   #6
Exclamation Re: intermittent miss on accel
sounds like what i have.i did a tune upa nd timing and now my car isnt just missing.its totally backfiring.its not the firing order,map sensor or pressure regulator. i think my pump might be going but i can hear it clearly when i turn the key and the exhaust smells REALLY rich.anyone have any ideas?
1988fordproblem is offline   Reply With Quote
Old 08-28-2006, 09:28 PM   #7
MonteCitan's Avatar
whooo back from the dead..
sorry...
erm..
my problem ended up being a faulty coil --
if you're backfiring that badly you either have a leaky injector or your distributor is entirely out of time.. (maybe whomever set it was wrong?) or perhaps your rotor is damaged/broken?
where exactly in NJ are you? (I'm right near vineland..) perhaps I could try to help you out?
do you have AIM?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-30-2006, 09:34 PM   #8
well.i did the timing myself.and i think it kight be an injector as well.only thing is that its not leaking becauyse the only gas smell is when i sart the car and not while its runnin. i myself am from jackson.and my aim adress is firehellfire.if you can help me out it would be great.ive spent so much money trying to find out the problem.do you have an obd scanner.that would REALLY help
Old 09-04-2006, 06:52 PM   #9
Zim
Zim's Avatar
Coil pack is what i would have suggested next... I had that problem for a while and couldnt figure it out for the life of me. Glad you got it goin.
I like toys
2000 Mustang GT - Intermittent Driver Side Sound 3ricchu Mustang Audio & Video 1 07-07-2010 10:06 AM
very noticeable shaking/bad accel blackonblack Pre-2005 V6 Mustang 6 04-30-2010 07:35 PM
Sometimes I miss her... MarkuzLS1 The Bar 23 11-22-2007 02:19 PM
Miss Alabama now Miss America 2005 Brent The Bar 16 09-20-2004 04:44 PM
10:12 AM
