Starting engine ???? - Mustang Evolution
Old 10-24-2004, 07:37 PM   #1
StreetRacer4371's Avatar
i have a 95 gt auto...when i turn my key my engine turns over then i release the key like you normally would but then it hesitates then the engine starts running...anyone know why or how to fix it??
StreetRacer4371 is offline   Reply With Quote
Old 10-24-2004, 09:50 PM   #2
I liek gramer
WhiteStang99's Avatar
not sure without hearing it. Maybe you aren't holding the key over as long as you should...?
Old 10-25-2004, 01:03 PM   #3
MonteCitan's Avatar
just crank it a second longer and it won't feel like that.. most 4.6's I know of do this, its actually fun to see how many start by themselves with just a flick of the key
however when I first got my 02 it did this bad.. it felt like it caught so I'd let go of the key, there'd be a moment it does nothing, then it'd fire up...
I replaced the air filter and fuel filter and it hasn't acted up again..
Old 01-02-2005, 09:57 PM   #4
just hold the key longer mine does that to.
89'FIVE-O is offline   Reply With Quote
Old 01-02-2005, 11:57 PM   #5
red herring's Avatar
Send a message via AIM to red herring
Well, I'd say hold it longer too but there may be a problem you need to address here. Perhaps your alternator is a bit more worn out than it used to be, perhaps you can't get the spark you need, maybe your battery is a little weak, it's possible you can't get fuel initially, there are a million things that can cause it. How many miles are on your engine and what have you replaced done lately? It could also be the cold weather, it has been a bit chilly lately.
red herring is offline   Reply With Quote
starting with warm engine jorge gonzalez Pre-2005 V6 Mustang 1 08-04-2010 06:38 PM
Starting to build engine. upton7 General Mustang Discussion 2 07-21-2010 06:46 PM
starting off utmusicnut Pre-2005 V6 Mustang 12 08-28-2005 12:28 AM
Engine Starting... Ibanezplayer272 Pre-2005 V6 Mustang 9 05-31-2004 06:58 PM
05:26 AM
