Jimmy's Fiberglass Thread (1st time) - Mustang Evolution
Old 07-05-2009, 10:02 AM   #1
jimmy_beaner's Avatar
Region: Iowa
So I've decided to try to fiberglass a drainage pan for my hood. This is my first time working with fiberglass, so I thought I would take some pictures of the process.
I started by removing the hood, and cleaning up the louver openings more since it needs to be repainted anyway.
Next, I made a mold out of foam board, reinforced by some Gorilla tape.
This was test fit to the hood:
Then, the fiberglassing started.
Wax Paper as release agent on the mold.
And it dried/set:
Released from the mold:
Trimmed:
And test fit to the hood:
It does have some slight issues... I need to sand it and such. I also am planning on using fiberglass blanket around the edges to really help seal it to the hood. Let me know what you guys think. So far, those pictures represent 12 hours from starting of mold making to trim.
Old 07-05-2009, 11:54 AM   #2
hottcobra's Avatar
Re: Jimmy's Fiberglass Thread (1st time)
moral of the story is don't open up the vents on the hood of a car with a 2V motor
Just kidding Brian. It looks great. You did an awesome job for your first time using fiberglass. Gonna look really good finish sanded and painted.
Old 07-05-2009, 12:11 PM   #3
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
im just curious, does your design still allow heat to be extracted? or does it just drain water away from your engine?
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-05-2009, 12:26 PM   #4
Region: Iowa
yeah, I didn't know that when I started. I'm kinda sad because I know what would've made it even better. 1) doing it during the day light... 2) making sure the blanket is overlapping both sides.
I'm not sure. My #1 priority is just protecting the engine. I don't see why some heat wouldn't escape.
Old 07-06-2009, 07:22 AM   #5
so all the air flow is now no more as the drainage pan takes up all the air flow potential?
Old 07-06-2009, 07:28 AM   #6
Region: Iowa
we'll have to see if it still flows or not once it's done. If it doesn't... oh well.
Old 07-11-2009, 07:28 AM   #7
Region: Iowa
So the screen is mostly attached. I still want to put some fiberglass resin on the screen. And then I get to fiberglass the pan on. I just figured I would update this thread.
Old 07-11-2009, 11:29 AM   #8
Y2E0L0L5OGWT's Avatar
looks good for a first attempt to solve a problem...but I have (3) general questions about it though...
(1) How are you attaching the pan/holding it in place?
(2) Where is it draining to, down out the front of the hood over the radiator?
(3) Is the bottom/collection area of the pan going to be parallel to the ground? It may just be the angle of some of the pictures, but if so, how will the water drain if there is no slope to? The water will just collect & go nowhere...
Isn't it funny how a solution to one problem always causes multiple problems somewhere else?
Old 07-11-2009, 01:25 PM   #9
Region: Iowa
1) it will be fiberglassed to the hood.
2) It will drain hopefully between the radiator and the belt... there is a huge space there
3) It slopes downward toward the front of the car. Plus, the front is the only open area, so it'll have to drain there.
Old 07-11-2009, 05:07 PM   #10
2007STANG's Avatar
Region: West Virgina
I just like seeing people doing there own work you feel alot more pride in the work you have done and your car thats why i'm installing my own posi/373 gears
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 07-12-2009, 09:49 PM   #11
Region: Iowa
Re: Jimmy's Hood Thread *FINISHED*
And it dried/set:
Trimmed:
Old 07-12-2009, 09:50 PM   #12
Region: Iowa
I'm uploading pics now
Old 07-12-2009, 09:56 PM   #13
Region: Iowa
Old 07-12-2009, 10:14 PM   #14
2007STANG's Avatar
Looks Great how is it working ???
Old 07-12-2009, 11:20 PM   #15
Region: Iowa
it works perfectly. The water drains way up front by the radiator
Old 05-07-2010, 04:15 PM   #16
Region: Iowa
it's worth noting... the hood still functions perfectly. My buddy bought it from me when I got the Termi hood. He has no complaints.
New & 1st time owner from NY/LI Wolfsbain76 New Member Introductions & Greetings 23 08-28-2010 11:39 AM
Jimmy's Teaser Thread jimmy_beaner Pictures and Videos 39 05-14-2010 09:07 PM
Jimmy's 3/6/09 Photoshoot Thread! jimmy_beaner Pictures and Videos 47 03-14-2009 05:41 PM
1st one to start a thread ricklmesa Pre-2005 V6 Mustang 19 02-03-2006 09:15 AM
1st track time Murph00 Pre-2005 V6 Mustang 9 10-20-2005 07:32 PM
04:30 AM
