latest little "project" - Mustang Evolution
Old 04-05-2005, 04:12 PM   #1
Tbird232ci's Avatar
well, i was going to restore the factory wheels, using the method of painting the entire rim, then sanding the paint off the face, and smoothing out the face of the rim for a factory fresh look
didnt work too well, i used "Textured Metallic" from Duplicolor, and the **** is overly durable, i used those paint removing wheels for the drill, and took me 20 minutes to get a 3"x3" section down to the factory clearcoat, didnt even make it to the bare metal, so i repainted the rim, painted some spare centercaps, and threw em on the car
car is filthy, and only 2 are on the car at the moment, tomorrow, car will be washed, and better pics will be taken, and soon i should have new tires on the car
ID:	7706   Click image for larger version
Old 04-05-2005, 04:21 PM   #2
saweet
Old 04-05-2005, 04:28 PM   #3
1997grnstang's Avatar
Send a message via AIM to 1997grnstang
cool
http://www.mustangevolution.com/gall...oveoneclub.jpg
My Car
1997 Pacific Green Mustang
5-speed
1997grnstang is offline   Reply With Quote
Old 04-05-2005, 05:27 PM   #4
Kiljosh's Avatar
That looks pretty good actually.
Old 04-05-2005, 06:19 PM   #5
Tbird232ci's Avatar
suprising isnt it?
i got some more pics, but im a post whore, and a thread whore, so im making a new thread
Old 04-05-2005, 06:35 PM   #6
Haha...they look...different...just dirty to me
Old 04-05-2005, 06:40 PM   #7
Tbird232ci's Avatar
theyre about the only clean thing on the car
Old 04-05-2005, 06:41 PM   #8
Hahaha
Old 03-20-2006, 09:06 AM   #9
RGR
Send a message via AIM to RGR
Re: latest little "project"
I know this si an old psot but I have some wheels to restore,
how was your method "supposed to work", tbird232???
I have a set of Cobrs R's that need redone.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-20-2006, 01:40 PM   #10
Tbird232ci's Avatar
Well, the method i used wouldnt work on those wheels. If they were a flat faced wheel, like the snowflakes or 10 holes, it would have worked. Basically you paint the wheel, use a drill and scotchbrite pads and sand the paint off, then use the rear of te car as a lathe, and turn the wheels while sanding through grits, then clear
your wheels, youd have to bead blast and repaint.
Old 03-21-2006, 07:27 PM   #11
Bane-'s Avatar
pfft, your door didnt close
"Where in the World is Osama bin Laden?" - latest doc film by Morgan Spurlock SilentNoise The Bar 0 12-17-2007 06:23 AM
MTI RACING "Extreme Velocity" 454 "Southern Stingray" C6/Z = Awesome JROC Pictures and Videos 10 10-26-2007 03:33 AM
My HCI swap for "Project TONY" RGR Pre-2005 V6 Mustang 13 03-27-2006 09:35 AM
Update on project "Big Block Six" plstktnkr2 The Bar 16 03-21-2006 08:18 AM
My latest "Experiment", saving fuel $$$ RGR The Bar 5 06-02-2005 05:22 PM
05:50 AM
