'99 mustang gt rear 8.8 - Mustang Evolution
Old 10-03-2005, 06:12 PM   #1
Send a message via AIM to charkelly9
i picked up the rearend today and im gonna get started on this project this weekend. I plan on sanding it completely down and painting it black with duplicolor 500degree paint i have from doing calipers.
Next, im thinking about taking it to a shop and having it looked over and getting new bearings and seals
then, im planning on swapping my '03 axles rotors and calipers into the 8.8 rear cause they are in much better shape.. however the axles i think would be okay but i still wanna put my '03's on.
then im looking at buying quad shocks and possibly LCA's but i donno if they will be necessary... will my stock control arms and shocks work fine with this rear?
ID:	10874   Click image for larger version
charkelly9 is offline   Reply With Quote
Old 10-03-2005, 06:18 PM   #2
Re: '99 mustang gt rear 8.8
get all the rust off or it will bubble up and eventually start looking bad again.... they make rust paint that keeps it from comming though I do belive.
Old 10-03-2005, 06:18 PM   #3
your oem equipment will work fine on the new rear. About the only thing to look into is if you have ABS and this one does not or what not *traction control*
Old 10-03-2005, 06:40 PM   #4
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
good deal...and good luck on getting that sucker clean
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 10-04-2005, 05:09 PM   #5
how hard is it to swap axles? and even bearings.. could i do this without alot of experience
Old 10-04-2005, 06:20 PM   #6
swaping axles is easy (if you have traction control or abs stuff it makes it harder) as far as bearings not really sure.
Old 10-04-2005, 06:50 PM   #7
damn this abs and trac control ****... well anyone have an idea what its gonna cost to reroute it/.? ill probably end up having that done professionally and get ***-raped with labor costs
Old 10-04-2005, 06:53 PM   #8
Also how do i know if i have a 28 or 31 spine ... differences? advantages?
Old 10-06-2005, 09:47 AM   #9
Send a message via AIM to tedness
if it's a standard ford 8.8 off a gt it's 28 spline.
not sure the avdantages to 31 spline. someone will chime in on that.
tedness is offline   Reply With Quote
Old 10-07-2005, 06:46 PM   #10
31 spline is just stronger, trust me you wont break it with out some massive power or very very sticky tires and alot of power.
you have or dont have abs/trac control?
Old 10-07-2005, 09:20 PM   #11
i have abs and trac control; plus what are the odds that a 99gt rear with 55kmiles needs new clutches in the tlok?
Old 10-07-2005, 10:17 PM   #12
it should be fine, i wouldnt mess with new tlok clutches. does it not have tlok? abs wont be a problem i dont belive cuz you can just use your stock axles i do belive... not sure what else it takes.
Old 10-10-2005, 04:46 PM   #13
Zim
You want to **** me?
Zim's Avatar
Dont bother with quad shocks... If youre gonna put new LCA's and what not on it anyway, the quad shocks will essentially be worthless. Those shocks are there for wheel hop problems, If you havnt experienced it, you more than likely wont start.
I like toys
94-98 SALEEN rear bumper cover/Trade for cobra rear or cash alwaysthefinest Mustang Parts for Sale and Wanted 2 05-10-2007 11:32 PM
help removing rear bumber on a 03 v6 mustang whitev6stang03 Mustang Audio & Video 7 09-03-2005 08:35 PM
Looking a GT Rear Bumper / Right Rear Tail Light - 99-03 Model KrazyPony Mustang Parts for Sale and Wanted 18 07-28-2004 11:33 PM
03:56 AM
