Tore down the motor today. Ouch. - Mustang Evolution
Old 12-16-2009, 06:19 PM   #1
hopefully it looks worse than it is and can be bored out fresh. The intake ports all had sitting water in them as well, so they are going to need some love too. No rust in them at least. The upper intake is a bit moldy, so that's going to need love as well.
Old 12-16-2009, 06:38 PM   #2
Re: Tore down the motor today. Ouch.
Damn that does look rough. Whats all the goals for it?
Old 12-16-2009, 06:49 PM   #3
Get it running for now before the 4 banger gives up on life. Going to be fairly stock for now so I can keep it at a dd. Then I'll either do the 460 plans I had or a nice 351 swap.
Old 12-17-2009, 01:30 AM   #4
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
nasty
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 12-17-2009, 07:07 AM   #5
maybe its not as bad as it looks~ you will know soon enough though
Old 12-17-2009, 11:24 AM   #6
hottcobra's Avatar
It's not that bad. A 30 over bore will take care of that
Old 12-17-2009, 07:06 PM   #7
DarkShadows's Avatar
by the way rob. i found a whole 95 cobra forsale for 1200 bucks. has frame damage but the drivetrain is sound. let me know if your interested.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 12-18-2009, 07:54 AM   #8
at least you didnt find a kermit doll's head in one of the cylinder holes.
Old 12-18-2009, 05:48 PM   #9
I'm interested.
Old 12-18-2009, 08:15 PM   #10
That's not that bad man, you'll be amazed what a machine shop will do with the block. Definitely get it tanked and checked, well worth the money.
Old 12-18-2009, 08:22 PM   #11
Got prices....$225 for said tanking, boring, decking, freeze plugging, magnafluxing, and honing. Much less than I had expected.
However, I am going to look at the cobra mentioned above first. I could get a running motor, trans, suspension, computer, dash, wiring harness, console, accessories, and rear end I would need for a complete revamp for a fraction of what it would cost.
Old 12-18-2009, 09:59 PM   #12
pm sent
Old 12-19-2009, 05:24 PM   #13
Hmm....Everything looks hunky doory...don't you agree?
Old 12-20-2009, 01:47 AM   #14
upton7's Avatar
dood what the **** did you do to it lol
Old 12-20-2009, 02:48 AM   #15
how did you get curb rash on there???
Old 12-20-2009, 05:18 PM   #16
After looking at that you might want to shop for another block....depending on what caused that the block might be through.
Old 12-20-2009, 06:20 PM   #17
Believe it or not, the block looks to be in good shape. Only minor surface rust in spots in some of the cyls, a bulk of the rust wiped off with a rag. The skirts are all intact and clean. The crank looks good. The cam is good. There are no nicks, gouges, wear marks in the cyl walls. In fact, other than the couple of rust spots where the rings were rusted to the block, the walls all look fresh with the normal honing marks. I was quite shocked actually.
However, the block and crank will be going to the machine shop to verify conditions. Not 100% sure if I am going to stay stock crank or not since I obviously have to get new rods and pistons anyhow. May go with a mile stroke to 331 while I'm at it.
The cobra option is real and if I had the 1200 right now, I could get it. However, I don't have enough cash laying around to get it before christmas.
Old 12-20-2009, 06:31 PM   #18
sounds good, my friend picked up a 302 block that was painted and looked good... the painted part was covering a little broke place that pretty much made the block uselss
Old 12-20-2009, 09:42 PM   #19
you know its OBO right?
Old 12-20-2009, 09:51 PM   #20
Yeah. Called. Needs 500-600 deposit to hold it. I'm a bit short for a couple weeks. I'm going to call back when I have the cash and see if it is still avail.
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
Ouch PureVenom Pictures and Videos 11 12-03-2007 02:15 PM
Ouch !! Herbstang The Bar 8 08-26-2006 11:07 PM
OUCH !!!!! Herbstang The Bar 13 06-03-2006 08:43 AM
Get the Mach 1's motor back today BruThru2002 The Bar 8 11-03-2003 08:33 AM
11:49 PM
