HCI Results - Mustang Evolution
Old 12-25-2005, 07:20 PM   #1
slvr2000stang's Avatar
HCI Results
Here are the results from my new setup.
We gained 54 rwhp.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 12-25-2005, 07:34 PM   #2
Re: HCI Results
Dang, nice numbers man.
Old 12-25-2005, 07:35 PM   #3
Kiljosh's Avatar
Re: HCI Results
Lol that graph confused the hell out of me atfirst.
You have a 6? I always thought you had a GT
Old 12-25-2005, 07:36 PM   #4
Re: HCI Results
Yeh, auto 6 at that
Old 12-25-2005, 07:36 PM   #5
Re: HCI Results
That is my V6.
I also have a 92 GT
2000 Vert 4R70W
Old 12-25-2005, 07:36 PM   #6
Re: HCI Results
Auto Vert V6
2000 Vert 4R70W
Old 12-26-2005, 03:52 AM   #7
Thomas91169's Avatar
Re: HCI Results
so black is Torque, Orange is HP, blue is RPM, and grey is volts?
how come the tq and hp dont meet at 5252 like they should. and is that alternator output in voltage? do alt's really resist that much voltage under higher rpms? or is it the voltage of the car, and the drain of the ignition system coming in more at higher rpms
and i find it strange the RPM's climb is such a consistent slope.
cool stuff, youre power output to the ground finally matches your displacement.
-Thomas-
Old 12-26-2005, 06:44 AM   #8
Re: HCI Results
(Lambda) volts = O2 reading. That's how the dyno outputs the measurement.
As for torque not crossing at 5250.... It's the graph. I have a better one.
2000 Vert 4R70W
Old 12-26-2005, 11:02 AM   #9
Re: HCI Results
I figured you would have more torque than that.
Those are def very nice numbers though. Congrats
Old 12-26-2005, 01:17 PM   #10
RGR
Send a message via AIM to RGR
Re: HCI Results
We gained 54 rwhp.
Wow, I was hoping for those kinda #'s from a Dynojet, the previuos
best I had seen was a combo similar to yours using BV heads and an
old 207 cam... with a 5 speed! It was 236 RWHP so I'd say the better
cam really makes a difference. You'd be over 250 RWHP easily w/5 speed,
and probably right around 250 RWTq.
BTW, this is an SC grind y'all so that might make the difference in Tq
you expected Brent. I'm just tickled to death that it clearly exceeds
the 207 cam. The heads were ported somewhat mildly in order to
maintain as much low end as possible.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 12-26-2005, 10:53 PM   #11
Kiljosh's Avatar
Re: HCI Results
Whatre your mods?
Old 12-27-2005, 05:45 AM   #12
Re: HCI Results
Originally Posted by Kiljosh
Whatre your mods?
ASP Underdrive Pulley
E-bay CAI
FRPP 4.10's & T-lok
FRPP Aluminum Driveshaft
SCT Flasher & Pro-Racer Package
Global West full length subframes
Dual exhaust with H-pipe & Magnaflow mufflers
PI Stallion 3000 stall torque converter
Jerry Mod valve body shift kit
ported heads & intakes
220/226 Comp Billet cam
1.73 RR's
2000 Vert 4R70W
Old 12-27-2005, 04:10 PM   #13
wiarumas's Avatar
Re: HCI Results
wow.. impressive.
Old 12-28-2005, 02:55 PM   #14
Kiljosh's Avatar
Re: HCI Results
Very. Thats a big cam too isnt it?
Old 12-28-2005, 02:58 PM   #15
Re: HCI Results
Just a little old 220/226 comp cam
2000 Vert 4R70W
Old 12-28-2005, 05:00 PM   #16
Kiljosh's Avatar
Re: HCI Results
I have a 216/216, was under the impression yours is huge lol.
Old 12-28-2005, 05:04 PM   #17
Re: HCI Results
what kinda lift do you have?
2000 Vert 4R70W
Old 12-28-2005, 05:13 PM   #18
Kiljosh's Avatar
Re: HCI Results
Here hold on....
My Cam Sheet..
Im using 1.8 rockers with .545 springs
Old 12-28-2005, 05:42 PM   #19
Re: HCI Results
Ok,
I am running about .579 lift
2000 Vert 4R70W
Old 01-01-2006, 03:19 PM   #20
RGR
Re: HCI Results
IMO the torque might've been higher with the first cam but the
overall SC'ed setup will probably like the higher duration Kirk.
Good thing you sprung for the major Intake mods, or the cam
would probably be a real dog on a split port! The crossover tube
mods and big TB probably helped considerably.
Old 01-01-2006, 03:26 PM   #21
Re: HCI Results
The 4.10s make it jump off the line, so it's working out good.
2000 Vert 4R70W
Old 01-01-2006, 03:36 PM   #22
Re: HCI Results
Here is a before & after comparison.
2000 Vert 4R70W
0-60 and 1/4 mile results stangaroo Pre-2005 V6 Mustang 27 12-10-2009 02:26 PM
My HCI swap for "Project TONY" RGR Pre-2005 V6 Mustang 13 03-27-2006 09:35 AM
Need some help with my HCI swap Kiljosh Pre-2005 V6 Mustang 11 10-09-2005 06:34 PM
List of things that went wrong(HCI install) Kiljosh The Bar 9 07-01-2005 12:08 PM
Hci coolstang Pre-2005 V6 Mustang 13 02-07-2005 06:53 PM
10:07 AM
