collecting parts to swap out my AOD for T5 :) - Mustang Evolution
Old 03-16-2006, 08:54 AM   #1
Bane-'s Avatar
Well the AOD in my car has been leaking/slipping pretty bad, So I have been gathering some 5spd swap parts, to do the swap this summer So far I have:
T5
Bellhousing
Block Plate
Clutch Cable
Wiring
Pedals
Cross Member
Exhaust Hanger
King Cobra Clutch / Pressure Plate
Flywheel
Turbo Coupe Shifter
Hurst Shifter
Clutch Fork
Pivot Ball
Clutch Quadrant
Trans Mount
Just need little pieces here an there like shift boot, lower shift boot and shift knob and im pretty much done
Old 03-20-2006, 11:02 AM   #2
MonteCitan's Avatar
Re: collecting parts to swap out my AOD for T5 :)
sounds good man.. let me know how it turns out.. I'm curious manual to auto is an easy swap.. auto to manual is tougher..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-20-2006, 12:46 PM   #3
Bane-'s Avatar
from all my gathered research, the pedals are the biggest PITA in the whole swap. So Im already in the I have to do it mind set, now I just have to get up and do it lol. I need to go down and get 2 more jackstands before I start though..figured it be easier if the whole car is off the ground...yay for not having a lift
Old 03-20-2006, 01:44 PM   #4
Tbird232ci's Avatar
just get it as high as you can on stands, its not too bad
transmission swap (auto to manual) what parts? 6opka Pre-2005 V6 Mustang 8 04-02-2009 03:26 AM
AOD to T5 Swap Thread Kiljosh Pre-2005 V6 Mustang 0 10-14-2008 05:03 PM
splitport swap parts rydog Mustang Parts for Sale and Wanted 11 12-11-2007 06:40 AM
Need a list of parts for a I4-v8 swap sonic04edge 1979-1995 Mustang GT 9 08-10-2007 08:29 AM
Rearend parts for 8.8 swap?. slow232 Pre-2005 V6 Mustang 11 08-03-2003 01:37 PM
11:39 AM
