My latest project: - Mustang Evolution
Old 11-01-2006, 08:10 PM   #1
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
My latest project:
Not Mustang related...or even car related, for that matter... Anyway, I've been redoing the watercooling for my little LAN computer. Putting it in a slightly larger case, too. I've been taking some pictures along the way:
The old setup, I'm starting to take it apart:
The old setup, all over the bathroom:
Corrosion in the Storm:
Soaking Storm in Vinegar:
The new case, complete with hole for the radiator:
Mobo and 7800GTX out of the old setup:
Naked 7800GTX:
Motherboard with the waterblock on it:
Maze4 on the 7800GTX:
Doing some test fitting with a dead X-Connect:
What it looks like without the power supply in the way:
Watercooling all hooked up:
Filled up and leak testing:
Radiator and grill all mounted up:
I had some issues with leaking, but I think I've got them all figured out. It's going to sit out in the garage, with the pump running, until tomorrow afternoon when I get out of work. If it hasn't sprung a leak by then, I'll finish hooking everything up, and put power to the real components.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 11-01-2006, 08:13 PM   #2
Re: My latest project:
Sweet dude, it'll be nice to get that thing up and running again lol. That, and not having to dodge computer parts all over your house, haha.
Old 11-01-2006, 08:13 PM   #3
Fishers Stang's Avatar
man that is so sweet!!!!
Charles
Old 11-01-2006, 08:30 PM   #4
I love that case
Old 11-01-2006, 09:09 PM   #5
Thomas91169's Avatar
did the case already have the bezel and cutout for the WC Radiator?
something always scared me about WC, but pretty soon its going to be mandatory, no fans will be able to cool things down enough, especially when OCin comes into play.
so does the WC setup go from Pump-CPU-GPU-Radiator-Resevoir? or are the CPU and GPU on seperate cooling loops? i would think the same water that gets hot with the cpu then feeding it over the gpu would be warm to the point it negates the purpose. id want them to be on seperate loops, if at all possible. maybe a T/Y fitting could work :chin:
-Thomas-
Old 11-01-2006, 09:14 PM   #6
He cut the hole for the radiator.
Old 11-01-2006, 09:36 PM   #7
electronics by the tub.............
is it in there so you can work on it while your on the pot, anyways, nicely done
Kyle is offline   Reply With Quote
Old 11-01-2006, 10:04 PM   #8
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
that looks very nice man. My wires on my desktop are (and always have been) a big mess. You must be OCin a good bit with that cooling setup
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 11-01-2006, 10:11 PM   #9
lol he has them at the stock clock speed
Old 11-01-2006, 10:15 PM   #10
timpryor's Avatar
granted WC is great but something about water + electronics has allways made me nervous
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 11-01-2006, 10:20 PM   #11
That is nice.
JROC is offline   Reply With Quote
Old 11-02-2006, 04:03 AM   #12
MarkuzLS1's Avatar
Naw...not quite . I pulled the old setup apart in the bathroom so that I wouldn't get the coolant on anything that matters. No matter how much you drain it, you always find more coolant when you take everything apart.
I like turtles.
Old 11-02-2006, 04:11 AM   #13
MarkuzLS1's Avatar
That's exactly how it goes. That's a pretty strong pump, so it's moving some pretty serious water. It flows past the cpu and the gpu so fast, the actual difference in water temperature before and after the cpu or gpu blocks is just about neglegible. You certainly can't tell the difference by holding onto the tubes.
I originally got into this to cool my overclocking efforts. What I found, though, was the increase in speed wasn't worth the sacrifice in stability. Now I just do the watercooling because I like to tinker with stuff.
I like turtles.
Old 11-02-2006, 07:00 AM   #14
I need to get to building me a new rig soon looks nice
Old 11-02-2006, 02:58 PM   #15
ah thats what i figured with the WC. i dont have enough room in my current case or else id prolly go that route come january (PC Upgrade time again). i need to look for a larger and stronger case.
but yeah, i dont oc the CPU, just the GPU a bit, most the times i just use the settings it gives me when i click "Detect Optimal Settings" or whatever in the nvidia oc menu. but as far as CPU's go, for gaming rigs, they arent the weakest link, just get good ram and a video card and fast hard drives and youre good to go.
-Thomas-
Latest addition: MarkuzLS1 Pictures and Videos 12 09-19-2008 05:28 AM
The regal's latest project MonteCitan Pictures and Videos 16 01-12-2008 01:48 AM
latest little "project" Tbird232ci Pictures and Videos 10 03-21-2006 07:27 PM
my latest project Jayber Pictures and Videos 25 07-23-2004 12:02 PM
05:58 PM
