My Official New Dream Car - Mustang Evolution
Old 02-05-2007, 01:49 PM   #1
bluemustang's Avatar
:drool:
Old 02-05-2007, 01:52 PM   #2
Re: My Official New Dream Car
Glad the plate said what it was because I no clue otherwise.
I give this post an A for pics...but an F for presentation of information.
Old 02-05-2007, 01:54 PM   #3
x2
Old 02-05-2007, 01:54 PM   #4
I got you i was just working on it
engine Aluminum M96/70S Flat-6
position Rear Longitudinal
aspiration Borg Warner Variable Turbine Geometry (VTG) Twin Turbos
valvetrain DOHC, 4 Valves per Cyl
fuel feed Bosch Motronic DME 7.8 Fuel injection
displacement 3596 cc / 219.4 cu in
bore 100 mm / 3.94 in
stroke 76.4 mm / 3.01 in
power 410.1 kw / 550 bhp @ 6100 rpm
hp per litre 152.95 bhp per litre
bhp/weight 347.0 bhp per tonne
torque 780 nm / 575.3 ft lbs @ 2050 rpm
drive wheels 4WD w/PSM, PTM
body / frame Unit Steel
front brakes PCCB Ceramic Discs w/Brembro 6-Piston Calipers, ABS
f brake size 350 mm / 13.8 in
rear brakes PCCB Ceramic Discs w/Brembro 4-Piston Calipers, ABS
r brake size 350 mm / 13.8 in
front wheels F 50.8 x 22.9 cm / 20 x 9 in
rear wheels R 50.8 x 29.2 cm / 20 x 11.5 in
front tire size 245/30ZR20 Michelin Pilot Sport
rear tire size 325/23ZR20 Michelin Pilot Sport
steering Rack & Pinion w/Power Assist
f suspension MacPherson Struts w/Lower Control Arms, Coil Springs, Gas Pressurized Twin-Tube Shock Absorbers, Anti-Roll Bar
r suspension Multi-link w/Coil Springs, Single Sleeve Gas Pressurized Shock Absorbers
weight 1620 kg / 3571 lbs
wheelbase 2350 mm / 92.5 in
length 4450 mm / 175.2 in
width 1852 mm / 72.9 in
height 1300 mm / 51.2 in
transmission 6-Speed Manual or 5-Speed Tip-Tronic
top speed 318 kph / 197.6 mph
0 - 60 mph 3.5 seconds
Old 02-05-2007, 01:54 PM   #5
Herbstang's Avatar
+ 1
Old 02-05-2007, 01:57 PM   #6
you bastards i put the info up Hell even more info
Gemballa is one of the top addresses for discerning Porsche tuning. This specialist firm for car customizing from Leonberg is noted for its high-quality conversions, which, in terms of their quality, are equal in every way to the genuine article. Also, when it comes to power, customers always receive the best solution. For the current 997 Turbo, Gemballa is now offering a complete aerodynamics kit and an extra portion of power. The result is the Gemballa Turbo GT 550, which is an absolute sensation in terms of its appearance and driving dynamics.
Gemballa obtains a fiery 550 bhp from the 3.6 l 6-cylinder engine. Following modification, the boxer engine, which is forced by two turbochargers, delivers 780 Nm torque (production: max. 680), producing a significant improvement in flexibility. Gemballa attains these values by fitting a power kit comprising a complete exhaust gas system, including metal sports catalysts and a modified engine management system. The Turbo GT 550 requires less than 3.8 seconds to accelerate from 0 to 100 km/h. With overboost, a breathtaking 3.6 seconds are made possible. For drivers who are daring enough, the Gemballa hot-rod can accelerate to 318 km/h, making the Turbo GT 550 some 8 km/h faster than the production version.
To enhance the visual appearance of the power-boosted 997 turbo, Gemballa has developed a particularly elegant aerodynamic kit. The Gemballa front spoiler arrives at a perfect combination of elegance and sport appeal. It reduces the lift on the front axle and helps to diminish the drag. The side skirts continue the line beginning at the front spoiler. They help to make the car look lower and optimize the aerodynamics in the area of the rear wings. Discreet air inlets help to cool the tires and brakes, besides adding a touch of racing car flair... with which the Turbo GT 550 can be compared in particular in terms of the tail-end. This is because Gemballa has pulled out all the stops here, to ensure that the cars it passes (of which there will be many) are able to enjoy an impressive view. A particularly striking feature is the rear wing that has been significantly modified, compared to the production version. It features openings at the bottom to supply the turbocharged engine with additional "air to breathe". Its top is adorned by the impressive main spoiler, which helps to create downforce for the rear axle. The tailgate skirt has also undergone a complete make-over. Whereas the production version doesn't let you see below the surface, in contrast the Gemballa makes this possible through generous use of a racing grille. For example, the rear muffler is visible from the outside. The racing grille also encompasses the powerful tailpipes of the exhaust system - Gemballa simply moved them further up, thereby adding the finishing touch to this perfect racing look!
While the Porsche 997 turbo rolls off the line with 19 inch wheels, customers who opt for a Turbo GT 550 from Gemballa get one size bigger. The Leonberg-based customizer has chosen to fit the Gemballa Racing 20� Black Edition wheel in a composite look and featuring a stainless steel rim flange. The front wheels come in the dimensions 9 x 20, and the rear wheels in an 11.5 x 20 inch format. To allow the center of gravity to be lowered to suit the particular driver and to further enhance the handling, Gemballa also fits a coilover suspension. Gemballa is also currently developing a modified larger braking system to offer this power-packed vehicle even better braking performance.
Gemballa uses a complete stainless steel exhaust system to perform acoustic tuning. The awesome sound this produces, which is enough to give anyone goose bumps, clearly underscores the fact that this is not just any ordinary 997 turbo racing past. This sound is unique to the Gemballa Turbo GT 550! But be warned - it's addictive!
On the inside, Gemballa has fitted a new sports steering wheel with a 340 mm-diameter. For the interior, further customized conversions are, of course, available upon request.
Old 02-05-2007, 02:01 PM   #7
Zim
You want to **** me?
Zim's Avatar
Add another tally to the wall!
+1
I like toys
Old 02-05-2007, 02:03 PM   #8
every single one of you are ********
Old 02-05-2007, 02:33 PM   #9
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Robs car is my dream car... Just Cobra Commanders color
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 02-05-2007, 02:40 PM   #10
That's fine as long as you want the slower color...we all know redfire is the fastest 03/04 color.
Old 02-05-2007, 02:55 PM   #11
Justin's Avatar
Yea redfire alone is extra 50hp and 80tq to the wheels right....
Old 02-05-2007, 02:57 PM   #12
Not to mention lighter paint...improves the power to weight ratio.
Old 02-05-2007, 02:58 PM   #13
Justin's Avatar
+1
x2
Old 02-05-2007, 04:23 PM   #14
I passed some 16 year old in a EXTREMLY NASTY (DIRTY) 03 sonic blue cobra vert yesterday...
Old 02-05-2007, 04:27 PM   #15
Justin's Avatar
He needs to give it to me..... i would keep it clean and drive it like a Cobra... Not like a V-6.... Aint that right Rob
Old 02-05-2007, 08:26 PM   #16
any time i ever see any nice mustang it makes me frown its even worse when you see a cobra or saleen dirt as ****
The Official Car Cleaning Thread meteorachick Mustang Paint, Appearance & Detailing 41 02-25-2011 07:29 PM
First official photoshoot of the the new car Zim Pictures and Videos 25 05-08-2005 05:24 AM
What is your dream car? steedav6builder The Bar 65 12-08-2004 04:06 PM
The official take some pics of your car right now thread fast64 Pictures and Videos 36 08-14-2004 09:21 AM
Making a dream car Mach_Mustang_R Pre-2005 V6 Mustang 45 02-12-2004 04:25 PM
02:18 PM
