Lowering Car...Need Opinions - Mustang Evolution
Old 03-07-2007, 09:18 AM   #1
*DISCLAIMER*
If you are going to tell me not to cut the stock spings, save the keystrokes. They are linear springs, cutting won't affect them. It fits my budget at the moment and if I don't like them I can put the stockers back on. Plus, I have read up on this a ton and it works just as well as replacing them with aftermarket.
*/DISCLAIMER*
Ok, I am lowering the car hopefully this weekend, if not then next weekend. I have decided to go the budget route since I was able to fall into a complete set of stock 03 cobra coupe springs for free (Thanks a ton Brad :beer: ).
So, I am going to cut them instead of the $350 for the steedas I was looking at...or $275 for the H&Rs.
Here are some samples...albeit not a vert.
How does this drop look? Does it seem right or is it still a touch low? I think it is a squidge low...so instead of going 3/4 coil up front and 7/8 coil rear like he did, I am going to start with 1/4 coil front and 1/2 coil rear to try and keep the slight rake the car has. If it doesn't come down enough, I will just keep adjusting till I get it where I want it. I just don't want the slammed effect.
Before:
After:
Old 03-07-2007, 09:28 AM   #2
Zim
You want to **** me?
Zim's Avatar
Re: Lowering Car...Need Opinions
I guess Ill save my keystrokes.... but, you're wrong. It does affect them.
Have at it though!
I like toys
Old 03-07-2007, 09:29 AM   #3
Have at it though!
But you didn't save your keystrokes...you wasted them telling me you were going to save them.
Old 03-07-2007, 09:31 AM   #4
Zim
Zim's Avatar
No, I saved them cause I could go a lot more in depth than that... trust me, I saved them
Why not look for some used H&R's on corral? I see them going for 130-150 all the time, and that would be such a better spring for you. (Assuming this is going in the cobra?)
I like toys
Old 03-07-2007, 09:53 AM   #5
Herbstang's Avatar
Didn't waste too many strokes I cut and pasted
The first problem is it increases the spring rate at both ends, but usually not by
the same percentage, so frequently the rear spring rates increase more than the
fronts and the rebound frequencies go to hell. A car will *feel* comfortable
even with high spring rates if the rates are matched so that the rebound frequencies
are close, and usually with the rear a little slower. (Whenever you go over a bump
the suspension goes up and down several times before it settles. The rate it which
is oscillates is what I'm talking about.) If the rear oscillates faster than the front it'll
feel HORRIBLE, and will perform badly
Old 03-07-2007, 09:53 AM   #6
rydog's Avatar
Send a message via MSN to rydog
Cut em i used to do it to all my cars i think this is my first stang that i actually bought springs for and it is so low i think the guy i bought them from cut them and repainted them
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 03-07-2007, 09:55 AM   #7
rydog's Avatar
for sure mine feels that way now
Old 03-07-2007, 09:59 AM   #8
Ok, let's try and keep the comments to how the sample car sits. I don't care whether you think I shouldn't cut them or not. 1/2 the people that comment will say it is fine...1/2 will say avoid it like the plague.
Fact of the matter is, I AM cutting the springs. I am not buying replacements at this time. I have a free set of coupe springs (600# vs my stock 470#) that I will be cutting. If I end up not liking them, then I will get the replacements. If I end up liking them...then I saved $300.
So, any comments on the ride height of the car in the first post?
Old 03-07-2007, 10:00 AM   #9
rydog's Avatar
It looks a tad to low i would do what you suggested and do 1/4 and1/2
or maybe 1/2 and 3/4 if the first is not low enough
Old 03-07-2007, 10:03 AM   #10
Herbstang's Avatar
Too Low
Old 03-07-2007, 10:11 AM   #11
Scut95's Avatar
I like the height....maybe go just a tad bit higher if you don't want the slammed look.....in the end it'll probly look like the drop from an Eibach prokit....which definately isn't a bad thing
Old 03-07-2007, 10:26 AM   #12
When I cut mine, it took me about 4 times to get the height where I wanted it. Just remember one thing...you can't put the metal back on. I think a little higher than that picture with it slightly raked would look nice.
Old 03-07-2007, 10:35 AM   #13
That's why I think I am going to go 1/2 front and read...check it just to make sure...then go to the 3/4 rear and adjust the front any if needed.
Do you currently have cut springs in there now? Any of this oscillation occur for you that has been mentioned?
Old 03-07-2007, 10:43 AM   #14
Also, upon finding a calculation formula and some rough numbers, it appears my spring rate will go from 600# front/rear to ~650 rear and 630 front. I will get a more accurate number when I measure the wire size, spring width, and free coil count so plug into the formula properly.
My rough numbers were gained by solving for N and D in the following formula knowing K = 600 for stock springs.
None the less, the change in rate will still be below what the H&Rs I was looking at getting are (700#)...so I can't see how the ride would be worse. :dunno:
Old 03-07-2007, 11:11 AM   #15
Zim
Zim's Avatar
Im assuming you're changing shocks/struts too right? That will help your ride factor as well if you get some shocks/struts that are valved to the spring rate you'll be having.
As for the stance, I like it... but I like 'em low
I like toys
Old 03-07-2007, 11:13 AM   #16
Negative...The stock bilstiens will not need to be swapped out right away with the drop I am after. In the end, I am looking for...at max...a 1" drop...probably closer to 3/4"...it will not be that agressive to get out of the stockers effective range.
Old 03-07-2007, 11:14 AM   #17
Zim
Zim's Avatar
That gray car definitely has more than a 1" drop
I keep forgetting those cobras have the bilsteins... you should be good for a while.
I like toys
Old 03-07-2007, 11:16 AM   #18
Yes...yes it does. I am looking to max out at 1" like I said...gotta remember, I'm a 300# fat ***...I drop the car too far and I will be ridin on rails.
Old 03-07-2007, 12:21 PM   #19
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
i think that car looks good.
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 03-07-2007, 12:55 PM   #20
bluemustang's Avatar
I like the way that cobra sits in height but yeah def go a lil higher since your a big guy
Old 03-07-2007, 01:36 PM   #21
I have cut C springs...3/4 front and 1/2 rear.
Old 03-07-2007, 01:41 PM   #22
Any funny ocsillations when driving over undulating roads.
(wow, too many syllabols...must take a break now...my head hurts)
Old 03-07-2007, 01:44 PM   #23
that drop looks about right, its always best to need to cut more rather than to have cut to much... always... so it might takes some trial and error... just dont cut to much right off and remember verts have more weight on the rear~ so it might effect it more (technically shouldnt... but dont risk it as the rears are pretty easy)
let me know how hard the rears are to do AND TAKE PICS VERY GOOD ONES OF THE INSTALL!!!! we need a how to for it (the rear only I know the front) cuz i need to do it and want to know the quickest way.
Old 03-07-2007, 01:48 PM   #24
I read a write up about it today and the rears seem a lot easier than the fronts...the springs actually fall out on their own in the rear from what I read.
When I do it...I will take detailed pics of the process. Hopefully Gabe (Modular2valve) gets back with me and we will make this a driveway job.
Old 03-07-2007, 01:49 PM   #25
Yep we could use some more Mustang Articles
Old 03-07-2007, 01:51 PM   #26
Yeah, I am working on one for "How to mod your 03/04 cobra start to finish" for anyone that comes in later. Haven't really ever seen one anywhere else...and we have one for V6's...so, I am working on one for 03/04's.
Old 03-07-2007, 07:57 PM   #27
No problems here besides scraping lol.
Old 03-07-2007, 08:38 PM   #28
bbunt302's Avatar
I'm saving keystrokes.
Scary stuff.
Old 03-08-2007, 01:16 AM   #29
I don't know this, but aren't those spring rates a little on the stiff side for a convertible Cobra even with subframe connectors. I know people say H&R Race spring are but I think their something like 750 front and 650 rear. Why don't you just cut your stock springs. :dunno:
For the next part I'll just save my keystokes.
JROC is offline   Reply With Quote
Old 03-08-2007, 07:07 AM   #30
from my understanding you support the rear and unbolt the LCA bolt from the tq boxes and lower the rear and they fall out.. just not 100% on that.
Old 03-08-2007, 08:33 AM   #31
You don't cut your stock springs on a vert because they are way too soft. 470# springs are what cause the wheel hop to be so harsh in a vert vs a coupe.
Aftermarket springs are anywhere between 650-750 rear for the vert styles. Cutting the stock coupe springs will put me at the bottom of that range.
Old 03-08-2007, 08:41 AM   #32
I definatly need H&Rs or mm coil overs if your rear spring install goes smooth I may do it soon.
put lowering springs on my car and raised it? electricstang Pre-2005 V6 Mustang 23 07-14-2006 04:18 PM
lowering the car OXstang11 Pre-2005 V6 Mustang 29 10-29-2005 08:43 PM
Lowering my car eddied Pre-2005 V6 Mustang 6 11-26-2004 11:58 AM
Lowering car question leo95 1979-1995 Mustang GT 9 11-11-2004 03:00 AM
Lowering my car? white99 Pre-2005 V6 Mustang 7 03-16-2004 10:20 AM
10:32 PM
