New Parts - Mustang Evolution
Old 04-12-2007, 02:55 AM   #1
New Parts
BilletFlow IRS Cover Brace.
Maximum Motorsports 14mm IRS Subframe Mounting Bolts.
Maximum Motorsports - Low-profile IRS sub-frame bolts
Maximum Motorsports - Front K-Member Brace
I ordered some MM full length subframe connectors when I ordered my k-member brace, but they have not gotten here yet.
I also ordered these parts the other day.
Reichard Racing 3/8" Wheel Spacer and Upgraded Lug Nut Kit [RR-WHEELSPACERKIT] - $0.00
UPR 96-04 Cobra Grill Emblem [UPR-5104] - $22.95
In a couple of weeks I will be ordering thes parts.
The complete IRS Delrin/UHMW/Aluminum bushing package - SVTPerformance
Engineered IRS Rear Steer Kit 1999 2004 Cobra at v8power.com
And then after a while I will order these and some tires.
StangSuspension.com - mm coil-over complete package - for 99-04 cobra with irs ...
I'm trying to make my car into a well handling Mustang but its getting expensive. I could put a Whipple and upgrade my fuel system for the cost of all this.
JROC is offline   Reply With Quote
Old 04-12-2007, 03:03 AM   #2
Re: New Parts
Definitely cool. Definitely not gay.
Old 04-12-2007, 03:11 AM   #3
Re: New Parts
Thanks.
Old 04-12-2007, 03:14 AM   #4
Re: New Parts
Sweet parts man. That thing is going to handle awesome
Old 04-12-2007, 08:06 AM   #5
SilentNoise's Avatar
Send a message via MSN to SilentNoise
Re: New Parts
Let me know what you think of the K-Member brace. I've always wondered how much of a difference they would actually make in the feel of the car.
Wolf Pack Car Club - Domestic V8 Performance Club (Edmonton, AB, Canada)
"If the automobile had followed the same development cycle as the computer, a Rolls-Royce would today cost $100, get a million miles per gallon, and explode once a year, killing everyone inside." -Robert X. Cringely
SilentNoise is offline   Reply With Quote
Old 04-12-2007, 08:17 AM   #6
Re: New Parts
Does the K member brace bolt up without having their k-member? If so, I might pick it up just to add a little more stability when I add my QA1 tubular brace on.
Old 04-12-2007, 08:24 AM   #7
Herbstang's Avatar
Re: New Parts
Very Nice
Old 04-12-2007, 08:25 AM   #8
Re: New Parts
Ya, it bolts on to your factory K-Member. This what the 1996-2004 one would look like installed from the underside of the car (they just haven't bolted it down):
Old 04-12-2007, 08:32 AM   #9
Re: New Parts
Originally Posted by SilentNoise View Post
Ya, it bolts on to your factory K-Member. This what the 1996-2004 one would look like installed (they just haven't bolted it down):
I guess I will have to compare it to my QA1 and see if it has the same connections. If so, I think it will be added to the list. Great...more parts.
Old 04-12-2007, 09:06 AM   #10
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: New Parts
nice.
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 04-12-2007, 09:24 AM   #11
bluemustang's Avatar
Re: New Parts
hell yea man that car is handle like a dream.
I like the direction you went with your car at the moment
Old 04-12-2007, 12:33 PM   #12
Re: New Parts
I 99% sure it will bolt right up to the car without removing the k-member. It looks real easy to install.
I'm going to wait until I get my rear bushing(I can't wait to tackle that job) to install all this stuff, but the people on svtperformance say that the k-member brace and some subframe connectors make a huge difference in the fell of the car, and that the k-member brace takes away the feel of the front tire seeming like they want to roll over themselves when turning sharp.
Thanks, I can't wait to get all this suspension stuff done so I can start looking at stuff like heat exchangers, ported blower, x-pipe, and other power adding mods.
Old 04-12-2007, 12:37 PM   #13
Re: New Parts
I will flat out tell you they (the FL SFC) will change the feel of the car. Mine went from flexy lexy to a level feel. Before when I Would launch hard, you could feel the car flex and lean to one side. Now when I launch, you can feel the whole front lift evenly and the rear end squat down evenly. Slostang here in town also found this out when he had his welded in last week...his is a coupe and he noticed the exact same change I did. No more flex. Helped wheel hop a little too because the weight transfer is better so now it takes a bumpy road to get the hop going.
Old 04-12-2007, 12:38 PM   #14
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
Re: New Parts
they stiffen the front end alot. I have the kenny brown brace right now and love it.
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 04-12-2007, 02:11 PM   #15
Thomas91169's Avatar
Re: New Parts
dam i miss that
-Thomas-
Old 04-12-2007, 06:47 PM   #16
Re: New Parts
nice, i hope to place an order like that with mm soon as well
Old 04-13-2007, 02:12 AM   #17
Re: New Parts
Let me ask you this, do the SFC make your tires spin/break easier. Someone told that SFC will make it harder to get traction under hard accelaration because the car is stiffer.(I guess kind of like stiffer rear springs will not let the car transfer as much weight to the rear under hard accelleration as softer springs) Not that that would really bother me as I told him that I would rather my tires spin than bounce all over the place from all this wheel hop.
BTW I hope to have all this suspension work done within 2 months but it might be 3 or so. And I need to call Stangsuspension and ask them about my subframe connectors as I ordered them Monday the week past and I got my k-member brace friday and still haven't gotten my SFC's.
Edit: BTW do the SFC's scrap on stuff easily. (Speed bumps, etc.)
Old 04-13-2007, 08:17 AM   #18
Re: New Parts
SFC are only a 1" loss of ground clearance, which is really only about 1/4" because they mount up higher than your side skirts, so no, you don't really lose anything there.
As for spin easier, I say no. Because the weight is being transfered evenly now, the tires don't break lose as much as they used to. It is much more of a squat and go now.
Old 04-21-2007, 12:18 AM   #19
Re: New Parts
I got my Subframe connectors today. Three weeks too the day after ordering them.
Old 04-21-2007, 12:20 AM   #20
Re: New Parts
Hurry up and get them welded in. You won't be dissapointed.
Old 04-21-2007, 12:22 AM   #21
Re: New Parts
I'm going to order my rearend bushing tomorrow and hopeful have them installed in a week or two along with my other parts.
v6 to true exaust. buying parts. am i buying the right parts steveyb927 Pre-2005 V6 Mustang 4 04-16-2009 10:04 PM
Parts: Smokedya95stang Mustang Parts for Sale and Wanted 1 09-02-2007 03:22 PM
parts on the way... whipster24 The Bar 17 06-18-2007 05:18 PM
Crazy Singe Port Performance Parts/ 94-03 Parts Forged! v6stanger Mustang Parts for Sale and Wanted 4 10-27-2006 12:13 PM
4.2 split port engine parts/torque converter/steeda parts Horse Mustang Parts for Sale and Wanted 33 03-17-2006 04:03 PM
08:21 PM
