Supercoupe V6 Engine - Mustang Evolution
Old 04-24-2007, 03:13 AM   #1
matthews.stang's Avatar
Originally Posted by http://www.bromell.com/the_stang.htm
Magnum Powers MAG3 induction system www.magnumpowers.com
85mm Magnum Powers TB
90mm Magnum Powers inlet and 4" K&N cone filter
90mm Lightning MAF
Ported manifold and inlet plenum (Wynn - Texas Thunderbirds) www.texasthunderbirds.com
Magnum Powers classic raised top
Magnum Powers front mount intercooler
SPAL 16" radiator fan
SPAL 14" pusher fan
Custom aluminum radiator (Mike 38sc)
Polished aluminum overflow tank
Cool-Flex radiator hose
Polished UPR radiator cover
BBK adjustable FPR
BBK 255 HP fuel pump
Accel fuel pressure gauge
60# iSiemens / Mototron Deka 4 fuel injectors
BHJ harmonic balancer
SCI stock size pulley set ( water pump / alternator)
SCI stock size Jackshaft pulley
SCI 10% blower pulley
SCI a/c delete pulley
Magnum Powers 10% overdriven crank pulley
Heartland tensioner pulleys
Heartland power steering pulley
Ford plug wires
MAC ceramic shortie headers
Melling high volume oil pump
"New" PS pump, water pump, alternator, EGR, belts, hoses etc.
Polished rad cap and UPR oil filler cap
Powdercoating by Jamie Hiscoe (V6sprout) www.905customs.com
Spec aluminum flywheel
Center Force dual friction clutch
Ford aluminum driveshaft
8.8" rear end w/ FRPP 3.73 gears
Steeda Tri-Ax shifter
MAC Cat back exhaust system
SCT Xcal2
Innovate LC-1 Wideband
Taylor battery relocate (to the trunk, duh)
All I can say is....
matthews.stang is offline   Reply With Quote
Old 04-24-2007, 07:35 AM   #2
Re: Supercoupe V6 Engine
whats the hp/tq?
Old 04-24-2007, 08:39 AM   #3
bluemustang's Avatar
looks good and what he said ^
Old 04-24-2007, 09:07 AM   #4
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
what they said and what kind of supercharger is that?
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 04-24-2007, 09:39 AM   #5
Looks like the stock supercoupe charger with a 10% pulley.
Very very clean. Just wish it made decent power...as in over 300
Old 04-24-2007, 09:51 AM   #6
Videos on the dyno...
http://videos.streetfire.net/video/b...1100e1da89.htm
http://videos.streetfire.net/video/2...1100e77252.htm
Dyno sheet...
And here's the rest of the story...
Originally Posted by Car2N
I had the car dyno tuned finally. My blower crapped out on me last week so I had to borrow another one so I didn't miss the tune appointment. These runs are using a Magnum Powers MPII M90 with a stock sized pulley. When I get my new blower I should see better results.
354 rwhp and 411rwtq (my new blower and a smaller pulley should get me closer to 400rwhp)
Old 04-24-2007, 09:53 AM   #7
All that on unported heads? Damn...I stand corrected.
Old 04-24-2007, 09:53 AM   #8
man not to shabby at all
Old 04-24-2007, 10:31 AM   #9
Thomas91169's Avatar
very nice, methinks though it would be sweeter if it was still in the car it should be............imagine getting spanked by a grandma car (IE Tbird). id like to know how much he spent for that setup.
-Thomas-
Old 04-24-2007, 12:13 PM   #10
Well, it is a 4.2L.
Old 04-24-2007, 12:36 PM   #11
not to bad just wonder how must boost bleed is he getting having to run the boost all around and then back into the engine. Or is that one going right down into the motor?
Old 04-24-2007, 01:02 PM   #12
looks like it goes into some sort of sidemount IC and back up again into the manifold, judging by this pic
or something. prolly abut 2 psi pressure drop depending on whatever cooler he runs.
-Thomas-
Old 04-24-2007, 01:03 PM   #13
the OEM setup is to run the boost from the blower down to the IC then back up instead of using a water to air exchanger setup~ and I was also thinking around 2-3psi~
Old 04-24-2007, 10:19 PM   #14
This is the upgraded IC that mounts with the radiator.
SuperCoupe Crank issues rinfield2004 Pre-2005 V6 Mustang 11 06-16-2010 01:23 PM
supercoupe m90 supercharger 3.8boii Pre-2005 V6 Mustang 4 04-19-2010 10:48 PM
Thunderchicken SuperCoupe Guts rinfield2004 Pre-2005 V6 Mustang 3 12-25-2009 09:45 PM
Supercoupe Build Up Black95GT Pre-2005 V6 Mustang 11 01-03-2004 10:01 AM
Supercoupe sc on 2002 3.8 bluestang44 Pre-2005 V6 Mustang 14 12-19-2003 06:46 PM
02:21 PM
