The Mustang Project 85' GT - Mustang Evolution
Old 01-22-2011, 04:54 PM   #1
Mike90's Avatar
This is my latest and graetest Mustang, LOL.
85' GT 351w 5spd yada yada
Put in a new Summit Radiator today and did some detailing.
This radiator has been sitting in my dinning room since Oct.
When I took kit out of the box it was quite impressive.
All aluminum construction, nice weld and thicker than the
Ford Motorsport that was in my last car.
Before
The old POS
The Install
Hope it works as good as it looks. Not sure about not having a shroud,
if it turns out to be an issue I'll run over to the pull a part and get a
set of Contour or Mystique fans, they fit perfect and work awesome.
I let it idle for quite awhile and it seemd to run a bit cooler. Need a real temp gauge.
Tommorow I am relocating the fuel pump and tightening up some exhaust
leaks.
They say the good die young,
I plan on living forever!!
Mike90 is offline   Reply With Quote
Old 01-22-2011, 04:57 PM   #2
MC770's Avatar
Re: The Mustang Project 85' GT
Looks like a sweet project! I f***ing love fox's
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-22-2011, 05:37 PM   #3
I love it. I have always loved the 4eye cars! That radiator looks great!
93CobraGuy is offline   Reply With Quote
Old 01-22-2011, 05:59 PM   #4
Titus Wadicus
svtlx's Avatar
great job...mystique shroud u say?....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-22-2011, 06:05 PM   #5
Mike90's Avatar
Yup just pull the whole fan assembly and strp it onto the mustang radiator.
Works great. I think I paid $17.
Old 01-22-2011, 06:12 PM   #6
Titus Wadicus
svtlx's Avatar
sweet...
Old 01-22-2011, 06:31 PM   #7
Mike90's Avatar
sweet...
You'll need relays and a thermostat switch. or some type of fan controller.
Old 01-22-2011, 06:57 PM   #8
Titus Wadicus
svtlx's Avatar
i was just curious..i run a flex fan with a factory v8 shroud.. im not an electric fan..fan. even though im most likely gonna run it on my 97 5.0 v8 conversion
Say hello to me and my first mustang project blue-saleen New Member Introductions & Greetings 14 06-01-2009 10:29 AM
1967 Project Mustang For Sale in Ohio monk1 Classic Mustangs 0 10-25-2008 05:16 PM
85' axle cowboyupdan General Mustang Discussion 3 03-21-2008 06:31 PM
CarDomain's project car: A v6 mustang w/ 400 hp WhiteStang99 The Bar 12 11-08-2005 08:45 PM
04:00 PM
