Before and after nighshades - Mustang Evolution
Old 10-09-2013, 03:20 PM   #1
pictures of my car before and after I used this product called night shades
ID:	131987   Click image for larger version
ID:	131989   Click image for larger version
ID:	131991   Click image for larger version
Mustangman705 is offline   Reply With Quote
Old 10-09-2013, 03:30 PM   #2
MidnightBlueGT's Avatar
Come out better than expected? Did when I did, its good for $100 cheaper.
Old 10-09-2013, 03:33 PM   #3
the lights look great!!
Old 10-09-2013, 03:35 PM   #4
Rm360's Avatar
Not bad! Did you clear and wet sand them they look a tad dull but it could just be the pic you took , looks cloudy out there!
Old 10-09-2013, 03:39 PM   #5
I bought the headlights from AM but did the fog lights, tail lights, 3rd break light and the side markers with 1 can for 14 dollars.. looks great no runs or drips.. they look clean.. didn't think something so small as blacking out the lights would make sure a huge visual difference ... saved a lot more then 100 bucks
---------- Post added at 03:39 PM ---------- Previous post was at 03:36 PM ----------
I have 2000 grit sandpaper and left over clear inacan from something in the past I was going to wet sand and clear but they look great just how they were.. thought I would have to sand imperfections out but went on like glass... we will see how the hold up... eventually I plan on buying new lights but for 14 dollars this is better then leaving stock till that day comes
Old 10-09-2013, 06:04 PM   #6
Slow4V's Avatar
Originally Posted by Mustangman705 View Post
I bought the headlights from AM but did the fog lights, tail lights, 3rd break light and the side markers with 1 can for 14 dollars.. looks great no runs or drips.. they look clean.. didn't think something so small as blacking out the lights would make sure a huge visual difference ... saved a lot more then 100 bucks ---------- Post added at 03:39 PM ---------- Previous post was at 03:36 PM ---------- I have 2000 grit sandpaper and left over clear inacan from something in the past I was going to wet sand and clear but they look great just how they were.. thought I would have to sand imperfections out but went on like glass... we will see how the hold up... eventually I plan on buying new lights but for 14 dollars this is better then leaving stock till that day comes
I thought you did the headlamps I was like damn ! Lol
Old 10-09-2013, 06:28 PM   #7
Kustumb's Avatar
That looks good! How difficult is the application? And how is the visibility?
Kustumb is offline   Reply With Quote
Old 10-09-2013, 09:02 PM   #8
Like. 2/10 difficulty and visibility is all on the amount of coats. Two is what I did my friend did d*** 6 lol and its way dark
Old 10-09-2013, 11:43 PM   #9
You can always polish it off though. I did 4 coats and they looked just about solid black. But polished them so much and they lightened over time that i want to re do them now and make them darker, in direct sunlight it almost looks like they aren't tinted.
Old 10-09-2013, 11:46 PM   #10
1slosix's Avatar
holy 4x4 batman...looks good though. i use to run tinted tails as well but after a while the red was just something i liked more
carving corners like a boss
Old 10-10-2013, 12:21 AM   #11
sam62893's Avatar
We all used to be high waters at one point slo. Lol looks good op. But like with everything else, you'll probably get tired of it and go for a new look
Old 10-10-2013, 12:40 AM   #12
1slosix's Avatar
yep...after my first '04 i realized these cars handle cut springs great so i went that route...
then with my '04 GT i went the cut route as well...loved the stance and weight shift when at the drag track
and finally my current car on SR springs for the stiffer rate
OP if you ever wanna lower it let me know i don't mind helping you figure it out
Old 10-10-2013, 12:57 AM   #13
Kustumb's Avatar
So what is the visibility like with your 2 coats? And can you take it off easily?
Old 10-10-2013, 01:01 AM   #14
1slosix's Avatar
if he cleared them then it would be a simple sand job to remove... if he left them not cleared then brake cleaner does wonders
06:21 PM
