Glow wire install - Mustang Evolution
Old 11-30-2013, 07:49 PM   #1
2011 Kona Blue's Avatar
Good evening all. I wanted to share a product that I haven't really seen talked about on here or other forums. I actually haven't seen this on cars but it's called glow wire. A buddy of mine installed this wire around on the inside driver and passenger side door panels . The outline of the entire dash board outline will be next. The wire comes in all sorts of colors and looks amazing. It's not bright to distract a driver but yet bright and looks amazing. It has the intensity of ones speedometer lighting. Here are a few pictures of my new interior lighting. It looks freaking amazing when dark. My system was set up to come on when the parking lights are put on. Any one else have this stuff. Click image for larger version
ID:	139111 Click image for larger version
ID:	139112 Click image for larger version
Old 11-30-2013, 07:51 PM   #2
That's pretty cool. Got any shots of what it looks like in the light? (What the wire looks like)
KoolPwny is offline   Reply With Quote
Old 11-30-2013, 07:59 PM   #3
Here are a few with the lights off.
ID:	139117   Click image for larger version
Old 11-30-2013, 08:34 PM   #4
it looks pretty cool like that too. I didn't know what I was looking at in the first pics hahah
Old 11-30-2013, 08:37 PM   #5
Thanks bro. It looks great a night and day. Really makes a great accent.
Old 11-30-2013, 08:38 PM   #6
so it turns on when your gauges/ headlights turn on?
Old 11-30-2013, 08:49 PM   #7
Exactly bro. They are wired into the head lights. Lol. When gauges on, the glow wire is on.
Old 11-30-2013, 10:15 PM   #8
TorchRed6's Avatar
i thought about doin that at one point but was afraid it would be too tacky during the day.looks good though. what size wire did you get and did you wire it directly into your headlights or what?
TorchRed6 is offline   Reply With Quote
Old 12-01-2013, 08:20 AM   #9
I agree about a fine line being tacky and just right. Lol. I got 15 feet of the regular thin wire and the 12 volt plug and play pack. My buddy wired it directly up into the headlights wiring. The door panels need to come off and the headlight housing switch needs to be pulled out but stay connected as other parts to under steering wheel to run wires. We need the 12 volt.
http://store.glowire.com/products/12...-%26-Play.html
Old 12-01-2013, 08:31 AM   #10
Screaming Mach's Avatar
Looks good!!
Screaming Mach is offline   Reply With Quote
Old 12-01-2013, 08:47 AM   #11
Originally Posted by Screaming Mach View Post
Looks good!!
Thanks bro. It did take a while to set it up. My buddy said it's not hard just time consuming because of the wiring. Of course when you know what your doing it's not hard. Lol. If your like me I have mechanical skills of pumping gas and that's it. Lol.
Old 12-01-2013, 10:28 PM   #12
TorchRed6's Avatar
12 Volt 10' Plug & Play - Glowire
did he run it through the 12v driver and then into the headlights? and how do you wire it together after you cut it apart? i want to line all the spaces in between the dash panels in red, but that requires alot of cutting.i dont want 100000 connections going into my headlights
07:34 PM
