Turbo S197 out runs a Hellcat - Mustang Evolution
Old 08-27-2015, 05:42 PM   #1
Seatown Stang's Avatar
Was down at the track the other day and watched a S197 outrun a Hellcat. The mustang looked like it was so close to popping the fronts off the ground.
https://youtu.be/e7YDeJKkam0
2015 Mustang GT Premium
Mods: Lund Tuned, AWE Switchpath Catback, AirRaid CAI, Eibach Pro-kit Springs, 3.55 gears, Ferrada FR2 20x9 and 20x10.5, APR Splitter, RTR front Grill, Steeda subframe braces, Steeda differential bushings, Steeda IRS bushing support, BMR Vertical Links, BMR Lower Control Arm Bearing kit (BK055), BMR Front subframe brace.
Seatown Stang is offline   Reply With Quote
Old 08-27-2015, 05:44 PM   #2
With how heavy the hellcat it shouldn't be hard to take one down with a few mods. A 450whp car weighing 3,000 pounds has the same power to weight ratio.
Old 08-27-2015, 05:46 PM   #3
Rapinator126's Avatar
The hellcat rolls out though. From a roll your going to need a lot more than 450 at the tires promise.
🍼and 🌽 fed coyote.
Rapinator126 is online now   Reply With Quote
Old 08-27-2015, 05:48 PM   #4
By mods I assume you mean forced induction. IDK if 450WHP would keep up with the Hellcat. The Mustang was running close to 750whp and just edged him out by 0.2.
Old 08-27-2015, 05:54 PM   #5
Drag racing you can beat one with 450hp as the coyote's have run low 10's to high 9's with 450-500 NA.
From a roll Though it's a different story
🍼and 🌽 fed coyote.
Old 08-27-2015, 05:59 PM   #6
Mind Blown
Old 08-27-2015, 06:08 PM   #7
If it was on a diet; it would be so much better.
Pick your poison.
Recon is online now   Reply With Quote
Old 08-27-2015, 06:11 PM   #8
Pick your poison.
Doesn't need a diet. Go race on from a 60 roll. But you will have to go on the first honk and him on the 10th to give you some false hope.
🍼and 🌽 fed coyote.
2005 Modified S197 :: 2005 Ford Mustang S197 Ray Spencer Member Garages 0 10-06-2014 03:32 PM
2015 challenger hellcat 707 hp TrackPak General Car Discussion 827 09-16-2014 08:48 AM
2015 Challenger SRT Hellcat Ish416 General Car Discussion 14 05-20-2014 09:00 PM
Check out this completely bad Turbo S197 Konawin 2011-2014 Mustang GT 7 06-09-2012 02:24 PM
07:57 AM
