chevelle on the dyno - Mustang Evolution
Old 02-24-2009, 08:17 AM   #1
hottcobra's Avatar
well I finally got around to it. I still have a ways to go. I didn't have big enough jets for the carb. in the set I had, so the car is running 13:1 air/fuel. the car made 310rwhp 380rwtq. It's got a lot more in it. having to keep the timing way down to be save.
Old 02-24-2009, 09:40 AM   #2
Herbstang's Avatar
Re: chevelle on the dyno
Nice !! 380 RWTQ sweet
Old 02-24-2009, 09:41 AM   #3
1234's Avatar
Nice. That thing sounds badass.
Old 02-24-2009, 09:50 AM   #4
hottcobra's Avatar
hoping to get the air/fuel right and get in the 400s
I need to make a video of it idling and a fly by
Old 02-24-2009, 09:55 AM   #5
Herbstang's Avatar
Hell Ya !@!!
Old 02-24-2009, 09:57 AM   #6
hottcobra's Avatar
I'm gonna try to get the vids today
Old 02-24-2009, 10:11 AM   #7
That was the longest dyno pull ever...
Also, keep in mind Louis...you were on a mustang dyno which reads lower. You numbers roughly converted to dynojet numbers are 337 hp and 414 using a 9% correction factor.
Old 02-24-2009, 10:13 AM   #8
hottcobra's Avatar
it's a big block=not fast reving. and it was a pull from 45mph to 125mph 2krpms 5.5krpms
Old 02-24-2009, 10:14 AM   #9
hottcobra's Avatar
and you should be outside working on your car. :
Old 02-24-2009, 10:16 AM   #10
On my way actually...was just checking the forums real quick. Decided to do the bushings in case I can't finish the headers in one day...I don't want to leave my motor resting on a $15 walmart jack for 4 days.
Old 02-24-2009, 10:19 AM   #11
I think I'm also going to drop my gas tank to do the pprv delete...can't wait to take a gas bath since it is about 3/4 full.
Old 02-24-2009, 10:20 AM   #12
hottcobra's Avatar
what's the pprv delete?
Old 02-24-2009, 10:38 AM   #13
It's a check valve in the tank that keeps pressure in your fuel lines. During hard shifting it will cause a hesitation sending your car super lean for a split second. Mine has been hesitating on me every time I drive hard for the last few months...
And I just realized I won't be doing that today. Looks like I will only be doing most of my bushings.
Old 02-24-2009, 03:29 PM   #14
sweet.
96 GT- Who knows what's in it.
Old 02-24-2009, 04:21 PM   #15
wiarumas's Avatar
sexy
Old 02-24-2009, 04:32 PM   #16
sonic04edge's Avatar
Send a message via AIM to sonic04edge
I love your car
Looking for a mustang
2001 Ford Explorer 4x4
2003 Ford F150 Lariat Screw
1998 Ford Ranger-The DD
sonic04edge is offline   Reply With Quote
Old 02-24-2009, 04:40 PM   #17
hottcobra's Avatar
made the video of it idleing and reving the mtor, but have to get home the upload it off the camara
Old 02-24-2009, 04:42 PM   #18
1234's Avatar
Off subject does my car have a pprv valve?
Old 02-24-2009, 05:23 PM   #19
Did you hit the breaks?
Old 02-24-2009, 06:23 PM   #20
Yes...all stock cars do to keep the fuel lines pressurized when the car is off.
Old 02-24-2009, 07:46 PM   #21
I wish I would of kept my 70 chevelle malibu. Sadly I didn't have time or money for it. Got a steal on it. Got it for 1500 with 73k original miles. Needed some int and body work, but ran great. Had a 307 with 2spd power glide in it.
Old 02-24-2009, 08:18 PM   #22
hottcobra's Avatar
I wish I still had a few of my cars. don't know where I'd put them
Old 02-24-2009, 08:21 PM   #23
Same here the chevelle and my 96 gt were the two I wish I really had.
Old 02-24-2009, 09:57 PM   #24
hottcobra's Avatar
here's a vid of the car's exhaust. it doesn't do it any justice. sounds sooo much better in person
Old 02-24-2009, 09:58 PM   #25
Hot sauce
Old 02-25-2009, 02:41 AM   #26
Scut95's Avatar
Very nice car! It sounds really good man
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 02-25-2009, 11:22 AM   #27
07stang's Avatar
mustang dyno? you can put any car on any dyno. can you explain to me the difference between a "mustang dyno" and dynojet? is there a camaro dyno? if so, i'm going to put my mustang on that dyno.
07gt. sct 93octane custom tune,bbk cold air intake,kooks LT headers,o/r x-pipe,borla stingers, ford racing 3.73 gears,19" tsw wheels,eibach sportline lowering springs, 12k hid headlights, clear turn signal lens, cdc upper and lower billet grille.
07stang is offline   Reply With Quote
Old 02-25-2009, 11:25 AM   #28
Mustang is the name of the company that makes the dyno: Mustang Dynamometer / Mustang Engineering: Chassis Dynamometers, Engine Dyno, Transmission Dynes & Tow Dynos; Dyne, Dyno, Dynamometers
Old 02-25-2009, 12:52 PM   #29
07stang's Avatar
ok. well y does it give you lower numbers than any other dyno? there are alot other companys that make dyno's.
Old 02-25-2009, 01:00 PM   #30
It is because of the way that the mustang dyno provides resistance. Many other dyno's are just free spinning. The mustang dyno more closely represents real world driving numbers because it puts resistance on the rollers based on the weight of the car.
Some of the other manufacturers like Dynojet also have this resistance capabilities, but not all models and it is usually an add on feature. Even so, the mustang dyno still usually reads lower. Sometimes it will read as much as 12-15% lower numbers. It all depends on the configuration of the dyno at the time of the pull.
The dynos without the resistance will generally read much higher than any dyno that has load resistance.
On a side note, I think I miss-spelled resistance about 6 different ways in this reply. Good thing for spell checker.
Old 02-25-2009, 01:13 PM   #31
Herbstang's Avatar
Hopefully that was a joke Please God let him be joking
Old 02-25-2009, 01:13 PM   #32
Also, as a proof in concept, and something I am really interested in trying out some time...you could go to TPS and get on their dyno, make a couple pulls....then shoot over to stang hi and make a couple pulls on their dyno. Cody @ Stang Hi has a loaded dynojet, so you would be able to see the difference between the two dynos on a same day pull type thing.
Old 02-25-2009, 02:20 PM   #33
07stang's Avatar
if you pay for one of the pulls i will be glad to do it at both places lol. i called tps today im going on the dyno next week. im waiting for them to call me back to well me when next week. they are in a meeting.
Old 02-25-2009, 02:22 PM   #34
07stang's Avatar
yes it was a joke about the camaro dyno. lol
Old 02-25-2009, 02:25 PM   #35
07stang's Avatar
you need a victor intake on that motor. way better intake.
Having fun in the Chevelle hottcobra Pictures and Videos 14 09-01-2009 10:56 AM
Chevelle is getting new shoes. hottcobra General Car Discussion 15 05-29-2009 07:49 PM
Chevelle went back on the dyno hottcobra General Car Discussion 23 05-10-2009 10:38 AM
New Chevelle Cd Justin The Bar 14 03-13-2007 12:43 PM
69 chevelle Falcon Mustang Parts for Sale and Wanted 5 10-14-2004 08:47 PM
02:33 PM
