Trunk rattle - Mustang Evolution
Old 11-11-2004, 10:49 PM   #1
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
Trunk rattle
I just put 2 12" kicker subs in my Car and when they are up loud at all i get a real bad rattle, so i was wondering if any of you have had or do have this problem and what i could do to fix it.
19ClearCobra96 is offline   Reply With Quote
Old 11-11-2004, 10:55 PM   #2
I liek gramer
WhiteStang99's Avatar
check to see if you can distinguish where the rattle is comin from.
license plate, spoiler, trunk panels, etc.
I stuck styrofoam on the impact points of the trunk. Helped a little.
Old 11-11-2004, 10:57 PM   #3
Region: Nebraska
What do u mean by impact points? where the rattle is comin from
Old 11-11-2004, 10:59 PM   #4
I liek gramer
when u close the trunk, where the lid impacts with the body of the car. Probably has those little springs there.
i laid some around the trim too, left and right of the latch in the middle.
Old 11-11-2004, 11:07 PM   #5
Region: Nebraska
if you could get pics that would be awesome but i think i know what you mean
Old 11-11-2004, 11:18 PM   #6
I liek gramer
no digi cam here in birmingham...
maybe somebody can let ya know with a pic.
I have a 99 btw, but i used to have a 97 and i don't think there's much difference in what i'm talking about.
Old 11-11-2004, 11:44 PM   #7
01GTType's Avatar
Send a message via AIM to 01GTType
I've had 6 cars that have had this problem. Its been both the top of the trunk lid to the license plate and frame. For the license plate they make a foam sticker thats about 1/4 thick to attach to the back of it and that takes care of that. The trunk lid itself there is a rockford fosgate foam spray that is dense enough to get rid of most of the rattle if you spray it on the right spots. Just turn it up and listen to where its rattling and spray and let it set up. Then go to the next spot. Thats a good way to get rid of the annoying rattles.
01GTType is offline   Reply With Quote
Old 11-11-2004, 11:53 PM   #8
Send a message via AIM to kaper232 Send a message via Yahoo to kaper232
I have always used Dynomat to get rid of the rattle...
http://www.crutchfield.com/S-Dtplcf8...search=dynomat
kaper232 is offline   Reply With Quote
Old 11-12-2004, 07:17 AM   #9
I went through my old car and tightened up each and every bolt in the trunk and then sprayed a type of foam over them, put a rubber grommet over the trunk latch, did the foam behind license plate thing, spent about 2 weeks trying to find each and every rattle in the trunk. Then...I turned it up and my driver's side door started rattling, so I said screw it lol
Old 11-13-2004, 10:40 PM   #10
chips's Avatar
Send a message via AIM to chips
something will always rattle.
when my truck was brand new, there was no rattle, but then my rear windshield started rattleing, then my passenger side mirror, a piece between the cab and the bed, etc., etc.
you're fighting a losing battle...
the only reason Dr. Dre produced "The Chronic" because the bible tells you to smoke lots of pot, and Oedipus used to blaze with the makers of Aqua Fresh tooth paste.
chips is offline   Reply With Quote
Old 11-14-2004, 12:46 AM   #11
Dom
Dom's Avatar
Send a message via AIM to Dom
You won't have to sound deaden the entire trunk. You just have to find the certain spots to do it in. One major weak point in the trunk is the rear deck. The next major spot, I believe, is the underside of the trunk.
Old 11-14-2004, 03:07 AM   #12
01GTType's Avatar
True dat!
Old 11-18-2004, 12:43 PM   #13
mysteed's Avatar
Send a message via AIM to mysteed
yep, also make sure that your third brake light isnt comming loose. that was one of my loudest rattles. i tightened the screws and it went away.
Sponsored by Super Six Motorsports
Tuned by Tim at Modular Powerhouse
My Mustang Pictures
mysteed is offline   Reply With Quote
Rattle Noise 04_GT 1996-2004 Mustang GT 4 10-06-2009 02:24 PM
Trunk rattle with subs ThaBear14 Mustang Audio & Video 26 08-22-2009 03:24 PM
Rattle jaredp Mustang Audio & Video 10 06-02-2007 01:55 PM
Dash Rattle?? Tranny Rattle?? ricklmesa Pre-2005 V6 Mustang 0 03-08-2006 07:19 PM
i finally got my exhaust but now theres a rattle... 1997grnstang Pre-2005 V6 Mustang 9 09-23-2004 11:34 AM
03:35 PM
