sub install - Mustang Evolution
Old 07-24-2003, 01:12 AM   #1
Send a message via AIM to el cheapo
sub install
ok, so i got a pair of Polk 10" subs and an amp. I read somewhere on here that there is a problem with the stock cd player not having pre-outs. I didnt quite understand that problem, since it seems to me that you would be wireing out of the tuner.. .
Anyway, my question is this:
Do i need to replace the stock cd player?
Do i need to replace the stock tuner?
Do i need anything else special other than a basic wireing kit to make this install.?
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 07-24-2003, 01:15 AM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
mustangworld has a how to how to add subs to a mach system.
Rellik is offline   Reply With Quote
Old 07-24-2003, 09:01 AM   #3
Black95GT's Avatar
Send a message via AIM to Black95GT
lol i got my subs hooked up to my stock AM/FM.
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 07-24-2003, 10:05 AM   #4
Inline Converters are available. Available at Best buy, they arent that expensive. What they do is tap into your rear speaker lines, and send it through a converter. Out of that converter are 2 RCA plugs that you can use as preouts.
I had them.. before I just didnt want to screw with them anymore and got myself a new headunit.
Old 07-25-2003, 12:39 AM   #5
Edit: What about the whats it called wire that turns on the amp when the head unit comes on?
will that sound as good as coming right out of the head unit? If so that sounds alot easier than removing the head unit.
Old 07-25-2003, 12:47 AM   #6
The quality will suck if you use them. trust me. Jst save of the money for a cd player with pre-outs. U will be much happier.
Old 07-25-2003, 01:11 AM   #7
so you think doing them like mustangworld says (using the data cable) is the best? And ill have to run a remote line, cuz i know my amp needs that.
also, i have a 2000 v6. That doesnt have the mach 460 does it? The install is the same though right?
Old 07-25-2003, 11:05 AM   #8
Um I don't thank Non-Mach systems have a data cable? I could be wrong though. Never even fooled with stock stuff.
If its Non mach then you would be SO much better of getting a aftermarket head unit. Do you know how much power a non mach head unit puts out? like 10-12 rms.......... :
Old 07-25-2003, 11:41 AM   #9
Thats just a remote switch wire. I never wired those directly into my head unit, because I want total control over my sub. So I wired it to a 12V switch. If I dont feel like bumping and still want to listen to music, I simpily dont turn it on. Also helpful when you're blasting and you see a cop.... flip, sub kicks off .
The quality wont be there, but it'll work. I eventually said F* it and got a head unit with preouts.
Old 07-25-2003, 11:56 AM   #10
yeah your prolly right. .
another question though:
Right now my tuner and cd player are 2 seperate units. So if i get an aftermarket headunit, ill have a big hole in my dash! What should i put there?
Old 07-25-2003, 12:06 PM   #11
One of these is a great idea!!!
Check out this thread of mine Zimstang makes them
Old 07-25-2003, 12:07 PM   #12
And here is a how-to for removing the CD player The stereo is the same procedure
http://www.232stangs.com/how_to/appearance/cd_removal/
Old 07-25-2003, 12:29 PM   #13
I believe is has the double din not like ours Evin....
Go to a local stereo shop and they should sell I kit that will fill up that extra hole in the dash with a coin holder thingy. Then you can buy Zim's switch panels and put them on.
Old 07-25-2003, 12:30 PM   #14
wow thanks for the help guys! and i might get one of those pony lights! thats super sweet. Zim you can pm me or e-mail me if you are reading this!
EDIT: yeah i know a dude who is going to help me with the install, he has those hook tool things. . . now i just need to figgure out what head unit i want. . and i also have to find these pesky little brackets that my amp uses to hold on the speaker wires and power cable. There are these posts that stick out and it takes these little gold brackets that slide over the posts and hold the wires on. Anyone know what im talking about? Know where to get these?
Old 07-25-2003, 12:43 PM   #15
Brent,
Just like mine was My head unit and CD player were 2 seperate units
Old 07-25-2003, 12:50 PM   #16
Originally Posted by Rellik
Brent,
My bad.....
El Cheapo,
Are you talking about something like that?
Old 07-25-2003, 01:05 PM   #17
hard to say, they look kinda like that. . . im at work now but ill try to get some pics on tonight when i get home.
those look round though, where mine are long cylinders.
Old 07-25-2003, 06:09 PM   #18
ok so my friend has a headunit he wants to sell its a JVC kd-s640, 40x4 watts, and has rca pre-outs. He wants like 50 bucks for it. What do you all think? Its pretty old, but he says it will play burned cds and it works good.
Old 07-25-2003, 06:32 PM   #19
If you like it, then go for it. It's your car, makt it to your liking. Sounds alright to me. If you can live with the looks, then go for it. I paid 200 for my head unit.
Old 07-25-2003, 09:22 PM   #20
thats alot better Cd Player than you got now. I would take it.
Make your life alot easier.
Make your music sound crisper to.
Old 07-26-2003, 01:18 AM   #21
cool thanks
Old 07-26-2003, 03:09 PM   #22
ok. . . so i just found a 15" sub in my garage. It sounds good when i hook it up to my home stereo, which pushes pretty hard.
So i am thinking this, Can i hook up the 2 10" polks and this unnamed 15" with the JVC headunit and a 200w amp? Am I going to need more amp? Thanks.
Old 07-26-2003, 03:36 PM   #23
Actually now that i have heard the 15" and the one of the 10"s i think i may go with just the 15. The amp is bridgable, so that should work out. What do you all think?
Old 07-26-2003, 04:00 PM   #24
I personally listen to music that is faster than a 15" can handle. If you're listening to long, drawn out bass, then go for it. IF you listen to faster music such as rock, I would suggest just the 2 10"s.
200 Watts may not be enough to push all 3 though. You may want to run 2 10's off of the 200W and get another 200+ watt for the 15". But Like I said, it all depends on your application.
Old 07-26-2003, 07:10 PM   #25
200 watts is pushing it on the two 10's.
If your amp is 200 watts peak then it is only pushing 50w RMS into each sub. which is not very much at all. What kind of amp do you have?
Old 07-26-2003, 10:50 PM   #26
its a precision power PC250
I think i may just hook up the 15 and when i get some more money get a new amp and add it in with the 10s.
how much wattage do you think an average 15 sub can handle?
Old 07-27-2003, 12:17 PM   #27
1200
Old 07-27-2003, 02:20 PM   #28
Well depends on the sub. A legacy 15 isnt going to be able to hold alot.....
A Kicker L7 15 would hold a #### load tho.
If you bridge that amp it has to be bridged at 4 ohms.
So that means that you will have to find a Dual 2 ohm Sub and then wire it in series to bring it up to 4 ohms
If you dont do this you will fry the amp.
Old 07-27-2003, 10:52 PM   #29
ok, gag! Why does this just always have to get complicated.
another install SaturnMan8227 Pre-2005 V6 Mustang 12 03-18-2010 11:52 AM
Where to install S/C?! SerbStang Regional Mustang Discussion 6 04-22-2008 09:16 AM
CAI Install 00BlackStang Pre-2005 V6 Mustang 10 01-27-2006 09:19 AM
Need Help with gauges install 02Stang Mustang Audio & Video 8 04-26-2004 07:45 PM
CB Install n8r The Bar 40 03-19-2004 09:22 AM
02:36 PM
