Getting front headlights off - Mustang Evolution
Old 11-23-2004, 11:50 AM   #1
I cant figure it out.... 96 Mustang
Old 11-23-2004, 12:19 PM   #2
Danger Dude's Avatar
OK here it is The front headlights have 2 post on the back of them that stick thru the headlight support assembly. looking down behind the headlight you will see the threaded post sticking thru and with black plastic adjusters at the base. if you look closely there are metal clips holding them in place you will be a pair of needle nose pliers to pull off the clips and the headlight will fall out
Name:	headlight retaining clip.jpg
ID:	4557   Click image for larger version
Name:	Head light post.jpg
Old 11-23-2004, 12:50 PM   #3
if it i just like the 02 then you will just have to take off like two little bars by pulling up and then the bulb is on the back of the head light threaded on, so you will have to twiast the buld assembly to the left.
Old 11-23-2004, 01:12 PM   #4
This is what I see
What am I suppose to remove
Old 11-23-2004, 01:21 PM   #5
remove that tab that is at the right
Old 11-23-2004, 01:37 PM   #6
Ponycarman's Avatar
I just did this on my 96.
There are three points of connection between the headlight housing and the body. One of those three has a metal clip, the other two do not. For the one point with the metal clip you pull it off, pull straight up.
For the other two you have to compress the two plastic nubs that hold the plastic plug in place. I have used channel lock pliers and long needle nosed pliers to do this though I suspect a worm gear type hose clamp lightly tightened will do it too.
Good luck.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 11-23-2004, 02:09 PM   #7
I liek gramer
WhiteStang99's Avatar
hahahhaha. 99+ 0wnz j00 in the headlight removal!
pull two tabs, untwist lights, you're done!
Old 11-23-2004, 02:29 PM   #8
Pull up on the tab. You might have to squeez in the black peice that the Tab clipped to to get it to slip through the hole.
Old 11-23-2004, 02:56 PM   #9
Headlights and corners are on omg they look so sexy... pics to come when Nate gets his camera over here
Old 11-23-2004, 03:09 PM   #10
Very cool...me wants pics
Old 11-23-2004, 04:36 PM   #11
Good luck.
Steve
i guess they are very different to 99+
Old 11-23-2004, 04:45 PM   #12
Yea alot different
Old 11-23-2004, 05:30 PM   #13
so my instructions helped
Old 11-23-2004, 08:37 PM   #14
KrazyPony's Avatar
Hmmm Corey...I recall you using like the back of a mallett and popping mine right out at the time we installed the front saleen facia onto me car...yes and thats why the one clip kinda went broke by accident by yourself!
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 11-23-2004, 08:47 PM   #15
Black95GT's Avatar
Send a message via AIM to Black95GT
Here is mine
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 11-23-2004, 08:51 PM   #16
Here is your what???
Old 11-23-2004, 09:10 PM   #17
hell yeah
Old 11-23-2004, 09:26 PM   #18
How would I get a mallet behind the headlamp and knock it out ?????
Now as I was installing the headlamp I pushed it in so I could install the clip and the post broke off!!!! I also fixed it didn't I HUMMMMM!!!!!!!!! That is also a caution to be careful if installing the ultra Clear headlights the stem is made of somewhat cheezy plastic !!!!
Old 11-24-2004, 06:26 AM   #19
Black95GT's Avatar
lol I forgot the link, its at my house not at school.
On the other side, where are pics Brent!
-Jason
Old 11-24-2004, 12:29 PM   #20
I liek gramer
Nate get lost?
Old 11-24-2004, 12:30 PM   #21
Nate get lost?
He was suppose to post the pictures before he went to michigan
Got to wait for Mike to get his up
Old 11-24-2004, 12:46 PM   #22
Fishers Stang's Avatar
Nate get lost?
no drunk
Charles
My new headlights Mustangfan2003 1996-2004 Mustang GT 12 12-03-2008 06:18 AM
Help with headlights sporter 2005-2010 Mustang GT 0 05-02-2007 01:41 PM
Headlights megax29 Pre-2005 V6 Mustang 5 07-30-2006 07:44 PM
My Headlights Black95GT Pictures and Videos 11 12-08-2004 08:23 PM
Stage 3 roush front OR keep 01 cobra front? SpectorV Mustang Audio & Video 16 11-27-2004 12:17 AM
01:49 AM
