Upgraded Speakers - Mustang Evolution
Old 12-07-2004, 10:05 PM   #1
Upgraded Speakers
Im considering upgrading the stock speakers on my 1999 v6, would i need to get new wiring or can i just use the existing ones? and whats better 2 way or three way, why?
DMAC is offline   Reply With Quote
Old 12-07-2004, 10:10 PM   #2
three way gives you clearer sound because you have three seperate speakers handling the different frequencies
you wont need any new wiring, if you buy from crutchfield.com they give you a harness. If not you have to splice the wires.
Old 12-07-2004, 10:12 PM   #3
Dom
Dom's Avatar
Send a message via AIM to Dom
For the wiring, you can cut the plugs and wire then up with the supplied wire with the speakers, most come with wire, or order from www.Crutchfield.com and they will send the harness adapters.
A two way speakers is a woofer and a tweeter while the three way is a woofer, tweeter, and super-tweeter. This all depends on what you listen to. Rap is generally more bass riden while rock is more midrange.
The best speaker setup is a component setup, like the Mach 460, where you seperate the tweeter and woofer so you end up with better sound staging.
Old 12-07-2004, 10:23 PM   #4
Yeh.. I have components in my doors...just put them together to make a 2 way speaker basically. Good lows and awesome highs..just need to replace my rear speakers to get the mids I want.
Old 12-08-2004, 09:33 AM   #5
ok when installing them, does it matter which of the stock wirers are spliced to the new ones.
Old 12-08-2004, 10:51 AM   #6
Well..it always helps to put the positive speaker wire on the positive speaker terminal...but it will run in reverse too.
Old 12-08-2004, 01:41 PM   #7
how do i take off the door panels.. anywhere i can get a detailed How-To
Old 12-08-2004, 02:06 PM   #8
I liek gramer
WhiteStang99's Avatar
i dont know about a how to, but first pry up the hard plastic part on the door, where the window and lock buttons are if u have those. There's a small notch in the top of it. Pull that out, and then pull up. You'll have to disconnect the switches from the panel, just a regular old phillips head screwdriver should do it if I'm not mistaken.
After that, pull up on the whole door panel from the inside. The whole thing will lift up and out a little, comes right off. After that, you should have access to the speaker. Might have to move some of that plastic crap on the inside of the door around a little, but you'll see it.
Just be careful when putting that door panel back on. It's easy to think all the clips are in place, but if one is off, it can be bad news.
Old 12-08-2004, 03:05 PM   #9
I did a how to in a thread a while back...I'll make a sticky next time I'm on my computer and post it for 99+stangs
Old 12-08-2004, 03:06 PM   #10
The only thing I'd change in this is before you pull the door panel up..there's a plastic "christmas tree" on the inside of the front door jam holding the panel in. If you're looking at the door with it open...look at the hinged side, look at the panel closest to this and that's where it is.
Old 12-08-2004, 03:27 PM   #11
I liek gramer
After that, pull up on the whole door panel from the inside of the car. Pull up on the very bottom of the door panel. The whole thing will lift up and out a little, comes right off. After that, you should have access to the speaker. Might have to move some of that plastic crap on the inside of the door around a little, but you'll see it.
let me change the way I worded something...
Old 12-08-2004, 03:43 PM   #12
Dom
Dom's Avatar
Don't forget about popping off the sail panel and door handle bezel.
Old 12-08-2004, 04:23 PM   #13
I liek gramer
I didn't have to.
Upgraded to a GT... tedness Pictures and Videos 21 12-04-2008 07:07 AM
How can I better my already upgraded system? Dark04ShadowV6 Mustang Audio & Video 5 08-25-2008 10:45 PM
My Future Upgraded V6 SuperItalian Pre-2005 V6 Mustang 13 07-11-2007 10:00 PM
Upgraded Let Me Know If You Get Any Errors Brent ME Site Help & Announcements 2 03-09-2007 08:38 AM
Anyone upgraded to Firefox 2.0 yet? fast64 The Bar 20 10-24-2006 04:58 AM
07:49 PM
