Installing a mach1 chin and delete? - Mustang Evolution
Old 12-30-2004, 12:28 AM   #1
Send a message via AIM to StangGt804 Send a message via Yahoo to StangGt804
Has anyone installed these two parts and are they hard to install?
0H3GT
StangGt804 is offline   Reply With Quote
Old 12-30-2004, 12:30 AM   #2
i havent installed any of them, but i know that the chin spoiler is just a matter of drilling some holes and putting in some bolts or clips
Old 12-30-2004, 12:45 AM   #3
sonic04edge's Avatar
Send a message via AIM to sonic04edge
Chin spoiler is easy however I would suggest having a second person there to help hold it while u drill. Might not hurt to have a 3rd person there to tell u if its lined up right.
Looking for a mustang
2001 Ford Explorer 4x4
2003 Ford F150 Lariat Screw
1998 Ford Ranger-The DD
sonic04edge is offline   Reply With Quote
Old 12-30-2004, 12:48 AM   #4
moved to the right forum
Old 12-30-2004, 12:55 AM   #5
Dom
Dom's Avatar
Send a message via AIM to Dom
With the chin spoiler, you could either use some clamps or tape to hold it up and then pop some body clips into 'em and then your done.
With the grille delete you just gotta turn a few screws.
Old 12-30-2004, 01:13 AM   #6
Yea im thinking of taping it down and then screwing it into place. Hopefully everything goes well.
0H3GT
Old 12-30-2004, 02:53 AM   #7
Dom
Dom's Avatar
Yea, I'm gonna do mine pretty soon. Still trying to get the three bends in it left from shipping out.
Old 12-30-2004, 09:22 AM   #8
V6STANG007's Avatar
Send a message via AIM to V6STANG007 Send a message via Yahoo to V6STANG007
Very easy install. the grill delete goes on in like 2 minutes. the ***** is taking the Stock grille off.
Jorge ~
Originally Posted by Danger Dude
OK you are right!!! Maybe I am the Old Crazy One
V6STANG007 is offline   Reply With Quote
Old 12-30-2004, 11:40 AM   #9
get a friend to help you keep the chin spoiler centered good, then just drill the holes, it probably wont line up perfectly side to side so DONT lien up one end of it and start and go all the way around.. cuz you will have a gap at the other end when you are done, so center it up first and maybe use a little tape to hold it in place along with a friends help.
the chin spoiler is easy, the hard part is getting the stock honeycomb off, you can take the front bumper off to make it alot easier... but you can also remove the two push pins in the middle between the head lights facing up and then bent the bumper back and reach under to the underside of the stock grill and remove the 4 bolts you will fee, then the stock grill comes out.
after that you can pull out the little place part behind this, (two push pins you need to pull out, look at the new peice to see where they are) then slide the new peice in place and use the two new push pins that it has that are currently holding down the radiator cover, they hold down both now.
bolt the horse up, slide the new place bottom peice on with 3m tape to make sure it sits flush, sit it down only after the bumper is back down and has its push pins back in it.
Old 12-30-2004, 12:59 PM   #10
Thanks guys for all the help and input! Im going to go put it on right NOW!
0H3GT
Mach1 Chin spoiler SaturnMan8227 Pre-2005 V6 Mustang 30 09-02-2008 07:36 AM
Installing Mach1 Grill Delete kit? chris7869 Pre-2005 V6 Mustang 11 03-14-2007 01:54 PM
grille delete/chin spoiler...the hassles tedness Mustang Audio & Video 13 03-23-2005 05:51 PM
pic request of mach 1 chin spoiler and grille delete.... project232 Mustang Audio & Video 16 03-08-2005 09:00 AM
mach1 chin spoiler drmac The Bar 3 10-21-2003 01:13 PM
12:40 PM
