Installing decal instructions. - Mustang Evolution
Old 12-30-2004, 02:51 AM   #1
Dom
Dom's Avatar
Send a message via AIM to Dom
Just wanna make sure I got this right.
- Clean the wax off by washing the area in dishsoap.
- Mix up some soapy water and spray it on the area.
- Position the decal.
- Let dry a couple of hours.
Gonna do the rear bumper decals I got from Mustang Tuning pretty soon. Just wanna make sure I get it right.
Old 12-30-2004, 10:52 AM   #2
I liek gramer
WhiteStang99's Avatar
sounds good to me, just make sure that you keep the area wet until you are completely satisfied with its location, cuz if you don't, you better get used to it.
Where is this decal going?
Old 12-30-2004, 11:13 AM   #3
Send a message via AIM to NJStang86
I believe its the bumper inserts he's referring to
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 12-30-2004, 11:37 AM   #4
its realy easy to move those around if you get the area really wet
Old 12-30-2004, 03:36 PM   #5
I liek gramer
lol, good call. I was getting rushed out the door when replying to this.
yeah, just keep it wet till you're ready for them to stick. Warm water works better I think.
Old 12-30-2004, 10:45 PM   #6
01mineralgrey6's Avatar
i cleaned the bumper with dishsoap. and used water/soap in a spray bottle when i put the decals on, and as said before keep it wet untill happy with position. then you may need to carefully press airbubbles out. work from the center out while diong that
-Tony
'99 cobra 'vert
Old 12-30-2004, 11:01 PM   #7
1) remove from container
2) put 10 dollars in envelope addressed to me
3) place stamp on envelope
4) mail envelope to me
5) finish install of decals
Old 12-30-2004, 11:25 PM   #8
Dom
Dom's Avatar
They wouldn't fit your bumper.
Got mine from Mustang Tuning for like $13.99.
Old 12-31-2004, 12:43 AM   #9
I liek gramer
Nope, diff bumper, sorry Brandon.
Yeah, few things I forgot to mention. I used rubbing alcohol to clean up the area. You want to do that REAL well.
And like Tony said, you want to work out as many air bubbles as possible. I used a credit card to smooth out the decal once I was happy with the location, but before it dries. You will most likely still have small air bubbles once you are done and it is set. I'd give it a day probably at least to be safe, then use a small small small needle to poke a hole in the middle of the are bubbles, and squeeze them out.
Old 12-31-2004, 10:42 AM   #10
Probably a stupid question, but do you install the stainless-steel inserts the same way?
-Frank-
Old 12-31-2004, 12:32 PM   #11
i would think so, same sticker material just the outer material is different
Old 12-31-2004, 12:44 PM   #12
I liek gramer
some of the stainless steel ones are actually domed inserts. I'm not sure how you would go about doing those, but I'm sure whoever you bought them from could tell you.
Manual or instructions upton7 The Bar 7 04-11-2009 11:07 PM
Need instructions on how to replace seatbelts midnight02 1996-2004 Mustang GT 3 01-27-2009 08:15 AM
HELP~B&M Hammer Shifter #81002 Instructions mustangblondie Mustang Audio & Video 1 03-09-2008 07:31 AM
Need Instructions for Headlight assembly Nick89GT94 1979-1995 Mustang GT 1 05-26-2007 07:50 PM
Help no instructions mohrnormal Mustang Audio & Video 3 02-11-2005 09:52 PM
04:06 PM
