good audio setup for expansion? - Mustang Evolution
Old 01-05-2005, 04:08 PM   #1
Send a message via AIM to tedness
i've looked into several ideas for an audio setup and for now i just want 1 sub, but be able to put in a second with re-wiring a new amp. so if i were to install this:
12" Rockford Fosgate Punch 2
@ 50-200w RMS & 400w peak
What amp should i get for this so i don't have to buy another when i get a second sub?
also, i have the stock head unit with single cd player. do i need an aftermarket one to wire it all in?
tedness is offline   Reply With Quote
Old 01-05-2005, 04:11 PM   #2
i always used to under buy on amps... brent will know probably.
Old 01-05-2005, 04:28 PM   #3
Is the sub dual or single voice and how many ohms
Old 01-05-2005, 04:33 PM   #4
4-ohm single voice i believe.
Old 01-05-2005, 04:54 PM   #5
Dont get single voice coil
Get Dual 2ohm subs for best wiring options
That way you can buy a amp at 200x1 @ 4ohms and 400x1 @ 2ohms and power that one sub then when you add another sub you can wire it to 2ohm
Understand what I am saying?
Old 01-05-2005, 06:18 PM   #6
ah ok. i'll look into that. next question:
when i re-wire for 2 subs, do i rewire at the amp only or do i have to go back through the car and etc?
Old 01-05-2005, 06:19 PM   #7
you will have only one set of RCA's comming back wiht a power wire and what not, the amp will have to be altered for mroe than one sub but thats all you will have to alter.
Old 01-05-2005, 06:42 PM   #8
this is a mono-amp right? is there an advantage to getting a 2 or multichannel?
Old 01-07-2005, 12:29 AM   #9
Dom
Dom's Avatar
Send a message via AIM to Dom
Mono is for subs. You don't bridge 'em.
Old 01-07-2005, 12:35 AM   #10
Mono = Bridged internally
This setup sounds surprisingly good gmantheman 2005-2010 Mustang GT 3 10-20-2008 10:26 PM
good rear suspension setup? notstock02gt 1979-1995 Mustang GT 6 05-01-2007 06:08 PM
Is this a good setup for my 95 Cobra 302?? black95SVT 1979-1995 Mustang GT 9 11-21-2005 04:40 PM
Audio DMAC Mustang Audio & Video 17 10-20-2004 11:44 AM
Lighning Audio??? Good Or Bad? Funky4.6VERT Mustang Audio & Video 22 08-23-2004 08:13 AM
02:28 AM
