Remove factory amp. - Mustang Evolution
Old 07-29-2003, 03:20 PM   #1
Send a message via AIM to ASSEMbler
Remove factory amp.
My car has a standard ford amp. Not a mach.
I had the PSEC(something like that) box I got to
allow the stock amp to turn on with an aftermarket head unit.
Problem is, the sound cracks and warps at loud volume.
I have top end 3 way pioneers and the factory amp must go.
ANYONE KNOW HOW TO BYPASS IT??
I can't find any info. Plenty on 99 and previous.
Mind you this is not a mach sys.
ASSEMbler is offline   Reply With Quote
Old 07-29-2003, 03:33 PM   #2
when you take your CD player out there will be a bunch of wires behind it.
Since yours is a 2000 I am not that familiar with By Passing the Factory amp on it.
But un hook all wires connected to your AFTERMARKET CD PLAYER.(Dont touch anything lese other than what is hooked up to your cd player now.) If there are more than one cables still hooked up let me know. ACT like your taking it out. Once you have all of the wires removed look in the back and there should be Two cables that are still connected. i am almost cetain that these are the Wires that connect the factory amp. Un hook these two cables.(Should just snap out) and hook the rest of your cd player back up and then everything should be fine.
trying to be as specif as possible
Old 07-29-2003, 04:20 PM   #3
Turns out best buy has a $9 harness that plugs into the lead into the amp.
SIG REMOVED FOR THE PRUDE
Old 07-29-2003, 04:48 PM   #4
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
You could just grab it ... and pull really hard
Rellik is offline   Reply With Quote
Running power around the factory amp to the speakers Kiljosh Mustang Audio & Video 0 01-06-2007 09:17 PM
Remove the popups PureVenom ME Site Help & Announcements 17 08-28-2006 11:19 AM
How to remove your upper intake... Dom The Bar 8 04-27-2006 12:07 AM
factory amp + system: Rellik Mustang Audio & Video 8 10-24-2003 06:31 AM
Used factory Ford 7.5 3.73s & T-loc --- Any Good? Stang01 Pre-2005 V6 Mustang 24 07-18-2003 04:40 PM
07:43 PM
