how to paintTail Lights - Mustang Evolution
Old 01-18-2005, 08:23 PM   #1
Matt'sredbeauty's Avatar
Hey what all would I need to do if I wanted paint my red 97 taillights, like setup wise, Thanks Matt
Matt'sredbeauty is offline   Reply With Quote
Old 01-18-2005, 08:24 PM   #2
paint the rim of the tail lights or the lens itself?
Old 01-18-2005, 08:25 PM   #3
The bezel , I want to paint them black, like do i need primer, or what since its plastic. Thanks
Old 01-18-2005, 08:26 PM   #4
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
i dont think you need primer but i could be wrong
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 01-18-2005, 08:28 PM   #5
I have no clue just wondering, before I messed it up, and I don't want to pay 100 for new ones.
Old 01-18-2005, 08:29 PM   #6
Bane-'s Avatar
id use some like 400 or finer grit sandpaper and use that to take the clearcoat off the bezels, its gone when it isnt shiney anymore, then prime and paint it like anything else.
just did my entire car with rattle cans...I thought I was fond of them before...now we are best friends, and sanded the whole car by hand so i can most likely bend steel if I tried
Old 01-18-2005, 08:35 PM   #7
you dont have to prime it
Wet sand it with 400-600 grit sandpaper till the clear is off then tape it up really good around the lens
Then you put 2-3 coats of base and 2-3 coats of clear on it and make sure to let it dry good
Old 01-18-2005, 08:36 PM   #8
I have some pictures around the house of me painting my last mustang and if I can find them i will put them up
Old 01-18-2005, 08:37 PM   #9
What kind of paint do I use, and where do I get it, like autozone, Paint for plastic or what?, Thanks alot for all of your help.
Old 01-18-2005, 08:38 PM   #10
I liek gramer
WhiteStang99's Avatar
I would personally check out the junkyards in the area first... Especially cuz there are probably some bezels already black out there, or even if they aren't they will be cheaper than new.
Old 01-18-2005, 08:38 PM   #11
Bane-'s Avatar
id still prime though just cuz paint sticks better to primer then it does to paint, even if it is roughed up with no clearcoat
Old 01-18-2005, 08:40 PM   #12
if the paint is cracked then yes you will have to prep and primer, but if not just take off the clear coat and paint on the basecoat. paint sticks to paint very well.
Old 01-18-2005, 08:41 PM   #13
First thought was to go to junkyards but not to many keep mustang parts on hand, they go quick, thats what the guy told me.
Old 01-18-2005, 08:42 PM   #14
The paint is not cracked its in perfect condition. hurts to sand paper them, but I want them black.
Old 01-18-2005, 08:42 PM   #15
Auto paint store, you can get a pint of black of your choice and a pint of clearcoat and thats all you need.
You do not need to primer it, if you sand it well primer isnt necessary
Old 01-18-2005, 08:44 PM   #16
do u have a paint gun and compressor?
Old 01-18-2005, 08:45 PM   #17
Yea those will be required.. lol
Old 01-18-2005, 08:46 PM   #18
paint gun and compressor?, nope don't have those, how much are they, or how much would all this cost in the end just to paint my taillights?
Old 01-18-2005, 08:46 PM   #19
and water trap for the gun.
Old 01-18-2005, 08:47 PM   #20
if you dont have that rent them.
Old 01-18-2005, 08:49 PM   #21
So about how much for this project?
Old 01-18-2005, 08:51 PM   #22
Bane-'s Avatar
rattle can! take ur time and just put more coats on it (its thinner) and it will turn out fine...
Old 01-18-2005, 08:51 PM   #23
depends on what paint you get.
Old 01-18-2005, 08:54 PM   #24
a guesstimate?
Old 01-18-2005, 08:57 PM   #25
Never will a rattle can touch my car
Old 01-18-2005, 08:59 PM   #26
should cost liek 150 with good paint since its a small area
Old 01-18-2005, 09:00 PM   #27
I can buy new lights for that, thank for letting me know, so I didn't waste time and money. Thanks
Old 01-18-2005, 09:01 PM   #28
it cost me 220 dollars for gallon of teal base, pint of silver, primer for fixing a few small dents(pint worth) gallon of clear, sand paper and degreaser(removing dirt and wax)
Old 01-18-2005, 09:02 PM   #29
If you already had a paint gun and compressor you could do it for 50-60 dollars
Old 01-18-2005, 09:04 PM   #30
yeah but h does not know how to do it so he will prolly end up messing it up a coupel of times
Old 01-18-2005, 09:05 PM   #31
Yeah but I dont' so I guess im better off getting some new ones, Thanks guys, you've all help alot,
Matt
Old 01-18-2005, 09:07 PM   #32
if you need more body work help hit me up.
Old 01-19-2005, 05:15 AM   #33
Bane-'s Avatar
u can do it with rattle cans for about 10 can of black and a can of clear...
Old 01-19-2005, 02:44 PM   #34
Dom
Dom's Avatar
Send a message via AIM to Dom
Buy the OEM black plastic ones to replace the bezel you have now. No paint needed. Just add some Mothers Back to Black every once in awhile to keep the shine.
Old 01-19-2005, 09:48 PM   #35
Kiljosh's Avatar
RATTLE CAN!!!
I used it on my bumper and side scoops. All I did was sand the fck out of them, primer, then I put 4 coats of base on and 3 coats of clear. It still looks fine 9 months later....
lights bzgt 1996-2004 Mustang GT 1 03-10-2008 09:44 AM
Swap my Cobra fog lights for your GT fog lights TheDad Mustang Parts for Sale and Wanted 1 01-19-2006 01:01 PM
Stop Lights vs. Red Lights bbunt302 The Bar 25 12-11-2005 01:49 PM
Guage lights and ac panel lights steedav6builder Mustang Audio & Video 15 03-11-2005 03:10 PM
FOR SALE: tail lights, head lights, clear corners, tail light covers, dvd, xbox games Zim Mustang Parts for Sale and Wanted 15 12-13-2004 12:45 PM
11:02 AM
