Interior Painting - Mustang Evolution
Old 05-17-2009, 07:57 PM   #1
blue-saleen's Avatar
Region: Utah
Interior Painting
I really want my interior to have a nice looking silver and blue theme (sadly the interior color is grey and not black) so i wanted to pop out the door panel piece that the power window controls are on, and paint it blue. could i do this? what is the best and nicest way to do so?
blue-saleen is offline   Reply With Quote
Old 05-17-2009, 08:00 PM   #2
Re: Interior Painting
It is definitely possible to do. Many people on here have done this to their interiors...someone with experience will chime in
Old 05-17-2009, 08:01 PM   #3
hottcobra's Avatar
PM this guy he did a bunch of pieces in his truck
Mustang Evolution - View Profile: sonic04edge
Old 05-18-2009, 01:11 AM   #4
OsirisGuy's Avatar
Go to local Hardware store and pick up some rubbing alcohol and Krylon Fusion paint, pop off those trims, rub them down with the alcohol to clean them and just spray with the paint. All there is to it.
The plastic door piece you can slide you're finger up top where the little indent is and pop the whole piece out (or use a flathead screwdriver - carefully!). I believe a few screws hold the button assembly in that unscrews with a philips head.
The center console can vary. If it's a 94-00 then you will need Ford DIN Radio Removal Keys which can be found in many places for very cheap. Pull up on the trim bezel around the shifter, it's only held in by clips. There shouldn't be any screws holding in the second trim piece (goes around the radio, HVAC, and vents) but keep a screwdriver handy just in case. Remove the radio and CD Player if applicable with the DIN Keys. Behind the top radio is a torx screw (I believe it's either a T15 or T20, but do not quote me). You'll more than likely need an extension to get it out. You can now pull the radio trim off, usually it's best to start at the bottom and work the trim off evenly side by side.
For the 01-04 model years, there are no (read: none) screws holding the top trim piece. You can just pull up the bottom shifter bezel and then the radio trim.
You can check out the article sections, there are some great tutorials with photos that show you how.
For the painting you will definitely want to head over hear where they have a great breakdown, how to and pictures.
Mustangworld Interior Paint how-to
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 07-25-2009, 12:42 AM   #5
yoshiStang19's Avatar
what about a chrome look to it cuz if i would do it i wanna take ma tan leater off and put black w wgite center leather and blk/chrome interior any links to a chrome dash kit
01 v6 AT convertable
yoshiStang19 is offline   Reply With Quote
Old 07-25-2009, 09:16 AM   #6
get the real spray paint i think 50resto.com sells it
Old 07-25-2009, 01:23 PM   #7
u should really sand the peices first with a fine grit paper then clean then paint
NickPic is offline   Reply With Quote
interior and exterior painting help blue-saleen Mustang Audio & Video 8 11-24-2009 10:56 AM
PAINTING INTERIOR 00STANG00 Mustang Audio & Video 9 10-28-2009 07:51 PM
Interior Painting BulletWalker General Mustang Discussion 1 09-01-2008 06:49 AM
Do-It-Yourself Interior Painting DropTop_Stang Mustang Audio & Video 17 02-03-2004 11:42 AM
Interior painting DropTop_Stang The Bar 8 08-17-2003 06:23 PM
07:22 AM
