need to make left headlight aim higher - Mustang Evolution
Old 02-11-2005, 08:27 PM   #1
Send a message via AIM to tedness
ok my dilemma is my left headlight is sagging too low, so the beam points down directly in front of the car rather than out like the right side. i need to know a remedy for this. its the actual assembly and not the bulb angle
tedness is offline   Reply With Quote
Old 02-11-2005, 09:01 PM   #2
Dom
Dom's Avatar
Send a message via AIM to Dom
You need to go get the headlight re-aimed.
Old 02-11-2005, 09:08 PM   #3
where do i get that done? also im pretty sure its the assembly because its kinda loose in the socket. ill check out the clamps tomorrow.
Old 02-12-2005, 09:31 AM   #4
Fishers Stang's Avatar
there should be some screws in the headlight sides, park infront of a building and turn the lights on and turn the screws, (thats how mine is but i have a sexy pre 99 keep in mind the driver will be lower then the pass..
Charles
Old 02-12-2005, 11:33 AM   #5
I liek gramer
WhiteStang99's Avatar
If you have a 99, there should be no problem with that. There is no way to adjust the entire assembly of the headlamp, because it fits in there one way. If the whole assembly is pointed down, either the spot where it is attached is fubared, or it's not put in place correctly.
Old 02-12-2005, 03:16 PM   #6
Dom
Dom's Avatar
In that case, grab your headlight and shake it and see where it's moving at.
Old 02-12-2005, 03:33 PM   #7
Hm...the left headlight is supposed to be pointed slightly lower than your left...
Old 02-12-2005, 06:32 PM   #8
Dom
Dom's Avatar
That's not possible.
Old 02-12-2005, 11:01 PM   #9
basically what happened was the two clips that hold it in are only sliding in, almost like the holes in the headlamps they slide thru are too big. so i might just adjust the clips so theyre a lil bigger and that will hopefully reposition the headlight up where i need it.
Old 02-13-2005, 04:58 PM   #10
Well..if you'll notice on newer vehicles, the passenger side headlight is pointed slightly higher...
Old 02-13-2005, 07:27 PM   #11
oh i know. but this is after puttin in the new assembly. i can barely see the road in front of me out of my left.
would higher octane gas? help? Scorpion1 Pre-2005 V6 Mustang 16 06-28-2008 03:42 AM
New Aim Name Brent The Bar 12 12-26-2005 04:20 PM
Higher RPM's Due to Electrical Load? Rellik Pre-2005 V6 Mustang 11 03-30-2005 09:45 AM
Gas price, any higher than me? NorwegianMustang The Bar 27 01-14-2005 06:26 PM
car sits higher any ideas? SpectorV Pre-2005 V6 Mustang 13 03-31-2004 06:57 PM
04:53 PM
