question about fog lights - Mustang Evolution
Old 05-28-2009, 12:07 PM   #1
The bumper I purchased to go back on my 'stang was from an '02 and it came with the fog lights which mine didn't have previously. Is the wiring harness a dealer only part or would I be able to pick it up from Auto Zone or NAPA or some place like that?
19Delta is offline   Reply With Quote
Old 05-28-2009, 12:18 PM   #2
upton7's Avatar
Re: question about fog lights
On mine i have a lil button on the inside to turn them off. If you don't care about that I would just wire them to your headlights.
Old 05-28-2009, 12:19 PM   #3
Well, I don't really use the coin holder anyway, and I was trying to make it look as stock as possible. I guess I could wire them to my headlights.
Old 05-28-2009, 12:22 PM   #4
upton7's Avatar
It's one of those buttons on the radio faceplate at the bottom its like the one for your defroster.
Old 05-28-2009, 12:23 PM   #5
upton7's Avatar
what you could do is go to a scrap yard and get a fog light button from a gt and just wire it to that switch and you could just turn them on manually.
Old 05-28-2009, 08:31 PM   #6
You can find the wiring harness for sale by itelf, as well as the fog light switches at some aftermarket companies. I think Late Model Restoration has them and CJ Pony Parts (haven't had the greatest time with them).
Or you could just do like upton7 said and wire it to the headlights. But if you want to switch them on or off, you can buy the switch (01-04 under the radio) (99-00 in the coinholder slot) and wire it independently, or buy the harness.
Old 05-29-2009, 01:25 AM   #7
OsirisGuy's Avatar
The fog light is an 899 bulb. You can head over to Motorcraft's website and pick up a 899 pigtail connector. While you are there you can pick up the OEM Fog Light Switch. If you would like to keep it as close to original as possible.
My fog lights were replaced with aftermarkets so the original pigtail connectors were cut off. I went onto eBay and picked some up so you can check over there too. A few other online shops carry the connectors.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 05-29-2009, 05:08 AM   #8
wow, late model restoration has the switch for 55 bones and the pigtails for 22 each. **** that, i'll just hardwire it to my headlight switch.
Old 05-29-2009, 06:21 AM   #9
CrzyBeautiful's Avatar
Send a message via AIM to CrzyBeautiful Send a message via Yahoo to CrzyBeautiful
IKR! I saw that as well as I was attempting to purchase some fog lights to "upgrade" my car. They have alot of things available that I need to get my '02 back to where it should be... but $29.99 for a fog light button? Seriously? Not to mention the fog light kit is $249.99...
"No Day But Today"
CrzyBeautiful is offline   Reply With Quote
Old 05-29-2009, 06:44 AM   #10
SaleenFiend's Avatar
IMO that's not expensive at all. Wiring harnesses and electrical switches can tend to get pretty expensive. Take into consideration that most wiring harness require a specific metal that may or may not be expensive. The switch actually come with a trim item also? So, IMO that's a pretty good deal.
Old 05-29-2009, 07:47 AM   #11
buying the harness from anyone is usually expensive, you can wire one up yourself, you will just need the plugs to the fog lights which you can get from ford or probably cheaper here: (but check first) Tousley Ford Parts Depot
wiring is pretty easy i can help if you want to do it yourself, pm me and I will tell you how to do it
Old 05-30-2009, 07:28 PM   #12
VMP tuning has the full fog light kit for 175.00 This includes everything, and you get the clear lens, look better than the oem ones. This is the cheapest I've seen a full kit with clear lens.
Just putting it out there
Old 06-05-2009, 02:10 AM   #13
Thanks for the heads up - Ill let you guys know how it turns out...
"No Day But Today"
Old 06-05-2009, 05:06 AM   #14
Thanks for the head up! It even comes with the fog light switch!
"No Day But Today"
Old 08-01-2009, 12:16 PM   #15
Ah, hell with it. I ended up buying the switch from ebay for 10 bucks and the pigtails from late model restoration.
Fog Lights PenguinFan Pre-2005 V6 Mustang 31 08-01-2009 01:32 AM
fog lights immenukka Mustang Audio & Video 22 06-18-2007 07:09 PM
COBRA FOG LIGHTS question ridenmystang Mustang Audio & Video 2 04-21-2006 10:45 AM
Swap my Cobra fog lights for your GT fog lights TheDad Mustang Parts for Sale and Wanted 1 01-19-2006 01:01 PM
Fog lights mustang22 Mustang Audio & Video 6 04-14-2005 11:43 AM
02:02 PM
