bridge - Mustang Evolution
Old 05-28-2009, 09:04 PM   #1
bridge
can anyone give me a site with pictures that clearly show how to bridge a 2-channel amp to 2 4ohm speaks
eddie1 is offline   Reply With Quote
Old 05-28-2009, 09:35 PM   #2
hottcobra's Avatar
Re: bridge
Let me google that for you
Old 05-29-2009, 01:29 AM   #3
OsirisGuy's Avatar
Re: bridge
Check out http://www.the12volt.com. Find their calculators page and search for the series/parallel calculator.
What is the amp rated at? Do you care about stereo or fade? If you do it probably won't be possible. The speakers will have to be wired parallel to each other then connected to the amp, which will keep them at 4 ohms.
EDIT: Is the amp bridgeable? Just realized it wasn't to keep it ohm stable. The amp will have to be bridgeable in order for it to work. Speakers will still need to be wired in parallel.
To bridge a 2 channel amp:
You will see the speaker out puts in some form of ++-- or +-+-
The bridgeable outputs are usually labeled, or each channel is labeled. Basically use the positive for one channel and use the negative from the other channel. So if it the if the outputs look something like:
CH A (+ -) CH B (+ -)
You would use CH A (+) and CH B (-)
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 05-29-2009, 06:59 AM   #4
SaleenFiend's Avatar
Re: bridge
Well over my head...
Old 05-29-2009, 02:24 PM   #5
OsirisGuy's Avatar
Re: bridge
Audio stuff is simple, hell if I can do it anyone can. Building an engine or some mechanical stuff, it will just boggle my mind.
OsirisGuy is right
2002 Mustang GT
Old 05-29-2009, 03:07 PM   #6
Re: bridge
Rockford Fosgate® - Woofer WiringWizard
I always use rockford fosgate whenever I hook my stuff up. Just put in your sub/amp impedance and viola.
19Delta is offline   Reply With Quote
Breaux Bridge Car Show rickf73 Regional Mustang Discussion 4 06-03-2010 10:11 AM
Bridge Collapses into the Mississippi River meteorachick The Bar 15 08-02-2007 04:07 PM
11:28 AM
